Old 01-18-2010, 10:58 PM   #1 (permalink)
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
do you need smooth wheels if you have skirts
im building rear skirts for my echo, maybe fronts, it has the stock toyota steel rims,that in mind do i need to also buy smoothies or install pizzia pans, or would that be a waste. I have heard that the rims might pick up air and blow it into the wheelwells but these rims dont look like a very effecint fan.
Old 01-19-2010, 12:26 AM   #2 (permalink)
The wheel are still "churning" air inside the wheel well -- the Hucho aerodynamic book talks about having close fitting inner fenders to reduce drag of the overall vehicle.
So, with solid covers, the air cannot pass through the wheel, and so the air gets churned less behind the skirt. And the part of the wheel that protrudes below the skirt is also helped.
Old 01-19-2010, 07:20 AM   #3 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Neil is right. Once you have skirts, for best results you still need to isolate each side of the wheel so there's no flow though.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 01-27-2010, 04:33 PM   #4 (permalink)
smooth
Ditto.
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
Civic VX wheels or aftermarket? travr6 EcoModding Central 8 03-07-2010 06:37 PM
Wheel skirts slowing me down? wagonman76 Aerodynamics 11 07-20-2009 12:41 PM
The finest Chinese cr*p that money can buy. (wheels & tires) lyd EcoModding Central 13 09-30-2008 05:41 PM
Will smooth hubcaps fit my 2000 Civic wheels? swoody Aerodynamics 15 09-06-2008 12:51 PM
