EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   A/C Condenser airflow needs - full grille block (https://ecomodder.com/forum/showthread.php/c-condenser-airflow-needs-full-grille-block-40901.html)
Cd 04-22-2023 11:53 AM
How do you guys handle the cooling needs of the air conditioner when you have a full grille block ?
How can you tell if the size of your opening is too small ?
From what I have read, when the condenser is clogged, your A/C just won't cool well.
That seems like an easy indicator, except that I have read that if you put too much stress on the A/C, it could blow the seals.
I live in Texas. A/C is mandatory for life.
cRiPpLe_rOoStEr 04-24-2023 02:47 AM
Maybe trying some NACA ducts?
aerohead 04-24-2023 11:25 AM
'A/C'
1) air flow to the coil would be a requirement. Walter Korff, of Lockheed Aircraft Corporation provided inlet and ducting geometry parameters for us in 1963. It's in my photo-albums somewhere.
2) a non-aspirated, heat-conductive 'panel', in which the 'coil' is thermally-bonded to the inside, as part of the belly,could serve the same function, with zero drag penalty ( ISUZU 'Glider' technology ).
COcyclist 04-24-2023 12:22 PM
The short answer is open up your grill and look for aero gains elsewhere.
I find A/C to be a pretty large hit to mpg. I would not do anything to make the A/C system work harder.
freebeard 04-24-2023 01:10 PM
I wonder if the metamaterial to radiate into the darkenss of space will be applied as a vinyl film?
Skin radiators might make a comeback.
Vman455 04-24-2023 03:04 PM
Measuring radiator flow.
freebeard 04-24-2023 04:21 PM
Curiously, AmateurAerodynamics chose the same vehicles as you. :)
[Bookmarked.]
Phase 04-24-2023 06:04 PM
i turn the ac on with max heat in the winter because its so rainy and humid here. if you dont, youll fog up inside. i had full grill block and no issues. then again, i was trying to provide heat in the winter, versus cooling in the summer
Piwoslaw 04-29-2023 01:03 AM
In my previous P307 I had powerlock motors to open the grille block.
http://ecomodder.com/forum/attachmen...1&d=1282824808
cRiPpLe_rOoStEr 04-29-2023 03:07 AM
That would be a good setup, yet finding some way to set a safety temperature to make it open automatically to prevent overheating is desirable.
