Old 09-12-2009, 08:49 AM   #1 (permalink)
Thumbs up Battery amp meter
I needed to ask if there is an inexpensive meter I could buy to measure battery amps? I have a motor amp meter in the instrument panel, but with the problems I hava had with range, This other meter seems to be a good thing to have. Have a good one. Watt
Old 09-12-2009, 12:41 PM   #2 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
What is this on? how many amps are you running?
I really like the amp meter on my PakTrakr gauge, it's a shuntless pickup, so it's pickup has a cable or like on my car a solid copper bar that you put the pickup around, otherwise you need a shunt and an amp meter, check on renewable energy web sites, electric vehicle web sites.
The Following User Says Thank You to Ryland For This Useful Post:
watt-a-mezz (09-12-2009)
Old 09-12-2009, 04:46 PM   #3 (permalink)
Thumbs up Battery amp meter hookup
Hello, Ryland. Thanks for the reply. I have a 1988 Nissan pickup ev, With a ADC 9" motor. Currently being set up for 84 Volts, as I could not buy another kdh 9500. The replacement is a kd 72300. So max motor amps would be 300 amps. Would I place a shunt on the positive battery cable between the pack and the motor? Then hook the wires to the shunt, as I did with the motor amp gauge? Watt.
Old 09-12-2009, 06:36 PM   #4 (permalink)
...beats walking...
...just a curious question: are you wanting to measure the quantity of current (AMPERES) going into/out of the battery, or the amount of electrical energy (CHARGE) remaining IN the battery?
...they're two different things: AMPERES is rate-of-charge (or discharge), like gallons-per-second, whereas CHARGE (COULOMBS or WATT-SECONDS) is like remaining volume, how much there is left in the tank/battery.
...some of the semiconductor companies actually make specialized IC-devices to measure battery CHARGE, although they're usually targeted towards laptop computers and cell-phones, but they CAN be scaled upward to handle 100's to 1,000's of times larger capacities.
Old 09-12-2009, 08:58 PM   #5 (permalink)
Thumbs up RE: charge or discharge
Hi, Old Tele Man. I was needing to find something to measure the rate of discharge, as I have heard motor amps and battery amps work differently. I do have a el cheepo harbor freight voltmeter I have wired in as a state of charge meter. I wanted to ask if there is a way to set it for battery amps as well. Thanks, Watt
Old 09-13-2009, 12:31 AM   #6 (permalink)
Ryland's Avatar
save your money and get one gauge, PakTrakr Multi Battery Monitor Battery Pack Monitor
it even has a setting that looks like a gas gauge F----E
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 10:27 PM
Replacing alternator with solar panel array on roof? blackjackel EcoModding Central 91 01-19-2012 09:19 PM
Solar charging two 12 volt batteries (parallel)... SKIN Off-Topic Tech 5 09-04-2009 03:58 PM
Battery Post Repair bennelson Fossil Fuel Free 4 10-17-2008 03:35 AM
Correct battery voltage ? groar Off-Topic Tech 2 09-23-2008 09:13 PM
