Can I get 60 mpg out of my Paseo?
I posted this as a poll on three different Tercel/Paseo forums. Thus far the votes have been (to my surprise) heavily favored to yes. Yes, this was even posted on ToyotaNation. Surprising difference between the Tundra and Tercel/Paseo members I'd say. Yet, the members of these boards are almost 100% interested in performance alone. Mileage has been mentioned maybe 3 times in the few years that I have been on the boards. I will mention I have a reputation for getting things done on the boards so people do tend to trust me more than the average joe. I wonder how much this has swayed the voting. Most guys are lucky if they are breaking 40 mpg with their cars. Yet, they believe I can get 60 mpg (162% old EPA highway rating for my Paseo)? Total votes thus far: Yes: 12 No: 4 Now I really gotta kick it into gear so I can achieve this. :eek: |
The answer, as always, is "it depends". :)
Under what conditions, and using what driving techniques? You could get 60 out of an unmodified Paseo with driving technique alone, with the right kind of P&G friendly route. But your average speed would probably be in the neighbourhood of 30 mph. |
Haha, yeah, I know. I didn't put any limitations on it. Although, in the ToyotaNation post I did mention I knew I could get 60, I just didn't know if I could get 60 on my daily commute consistantly.
I think you can. You've got a nice little car there. It should do it, unmodified. With a little bit of modding, it'll be a gimme.
I regularly hit 60 on my commute, but I haven't done it consistently enough to have a whole tank, yet. |
Daox -
I third MetroMPG and PaleMelanesian's motion. I consider the Paseo to be the "Toyota CRX" of it's day, so I think it's pedigree of low weight and thrifty little engine can win the day for you. Look at your @#^#$*&^#$ curb weight, for crying out loud : 1992-1997 Toyota Paseo Specs & Safety - 2/20/2008 http://consumerguideauto.howstuffwor...ta-paseo-4.htm Quote:
I agree with Metro -- it has to be under the right conditions, but I'll go for "Yes".
Have you recorded any 100% highway tanks, and if so, what was the result? My best tanks were during 55-60 mph trips (40-42 MPG), which is difficult in my case (here it depends on the wind). I did 40 once on a mixed tank with tons of technique and fresh oil. You have an advantage with the light weight and manual tranny. Best FE to ya! RH77 |
Jury is out.
At 123% you may have gotten all the low hanging fruit already. You may have to indulge in some adventures in gearing. |
I'm sure you can. At that point, it really comes down to how skilled you are as an hypermiler, and how lucky you get with traffic conditions.
I'm negative Nancy but I'll be the first to applaud you if you do. Short of a small part tank freak fill I'm doubtful -- of the car not you.
Thanks for the comments guys! |
A Paseo is similar to a Del Sol is it not? I would say yes based on that.
Yeah, its fairly similar. I do have a back seat, but an adult can't sit back there comfortably. Its a 2000 lb, 93 hp, 1.5l engined car with a small frontal area.
If you want to get some idea what kind of FE improvement is possible with a similar type of car (a stock Honda Civic CX) just by developing your hypermiling techniques, go look at the gas log of my car "KeepsOn'Rollin' at Greenhybrid.com (http://greenhybrid.com/compare/mileage/car/188.html)
I started out in the mid 40's to low 50's and ended up in the mid 50's to low 60's with the best summer tanks hitting 70mpg. This was before I started with the aero mods, so my speeds were in the 40 to 50mph range. |
lol, my curb weight is like twice yours. (good for you, bad for me...:( ) I'm gonna say yea. you can do it if you got 52 already man. 60's gonna be a breeze.
its all about goals
I truly belive you can.
It is a goal you set and after you attain it you set another. Given my own lack of tenacity, I may not be the one to coach. But that doesn't change my belief. !!You Can Do IT !!! We are pulling for you. As DPoV said, 52 was easy 60 is attainable. S. |
I was amazed how well that car rolled on my driveway.
I got 47 mpg in my old car. That had pretty much the same engine and transmission. If I had known about pulse and glide and engine off coasting. I am sure I could have gotten 60 mpg in that car easy. I think once the weather is a little nicer out, Doax should hit 60 mpg. |
I started using those techniques after my 03/02/2006 fill. http://forum.ecomodder.com/fe-graphs/graph11.gif |
