EcoModder.com
-   -   Canceling out pumping losses of throttle governed engines (https://ecomodder.com/forum/showthread.php/canceling-out-pumping-losses-throttle-governed-engines-8846.html)
greasemonkee 06-19-2009 01:12 PM
Tests have revealed that a vacuum on the crankcase is of negligible benefit of an otherwise stock engine.
At 7 in/hg of vacuum the seals were screaming bloody murder while drawing in air.
This thread can be considered null
Christ 06-19-2009 01:16 PM
They do this with vacuum pumps for race cars... yes, vacuum in the block is a good thing, and it actually provides more than "marginally greater" ring seals.
I'm not entirely sure how much vacuum they use, but you can get belt-driven vacuum pumps from Summit Racing and Jegs for the purpose.
hyperyaris 06-19-2009 02:12 PM
It is illegal in the US.
Christ 06-19-2009 02:13 PM
Source?
hyperyaris 06-19-2009 02:16 PM
www.supersixmotorsports.com/pdf/PCVBypass.pdf
What exactly is a catch can and how does it benefit? [Archive] - The Australian 300zx Owners Association
Oops ignore Australian one lol
Christ 06-19-2009 02:18 PM
Try again - that article had to do with bypassing the PCV system. What the OP is talking about involves using the OEM PCV system with a higher vacuum - i.e. still feeding the crankcase vent into the intake system to be properly recirculated and burned.
hyperyaris 06-19-2009 02:21 PM
Ah ok. I thought he was bypassing it. My mistake.
KJSatz 06-19-2009 02:50 PM
Honda's R18 has a system to help with that, right?
PaleMelanesian 06-19-2009 04:21 PM
Pulse and glide solves the problem.
