Old 12-20-2009, 06:29 PM   #1 (permalink)
Gen II Prianista
Rokeby's Avatar
Reduced tire friction on merely damp roads?
I momentarily posted this to the Tire Pressure/Handling string. I then
realized it was off topic there. It deserves its own consideration.
"Rubber friction on wet rough substrates at low velocities is typically 20%–
30% smaller than for the corresponding dry surfaces. We show that this
cannot be due to hydrodynamics and propose an explanation based
on a sealing effect exerted by rubber on substrate “pools” filled with water.
Water effectively smoothens the substrate, reducing the major friction
contribution due to induced viscoelastic deformations of the rubber by
surface asperities. The theory is illustrated with applications related to
tire-road friction."
This surely goes hand-in-hand with the idea that when it first begins to rain,
oil on the roadway floats to the top and causes slipperiness.
Hear Ye! Hear Ye! Read All About It!
The Following User Says Thank You to Rokeby For This Useful Post:
RRC (08-11-2011)
Old 08-11-2011, 04:03 PM   #2 (permalink)
The Ol' Oldsmobile - '02 Oldsmobile Alero GL2
90 day: 27.68 mpg (US)
That's pretty cool! Good to know.
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 276 03-14-2022 03:51 AM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
Tire size vs. hub width and weight limits Piwoslaw EcoModding Central 3 06-25-2009 06:50 AM
