CarBEN Model -- 1/24th scale model and 3D computer model for EV
Hello & welcome to the beginning of a project that I think/hope I can pull off -- I'm trying to build an EV from scratch. I have started with making a 1/24th scale (aka 1/2" = 1') model of the car I have been contemplating. It is approximately 13 feet long by 5 feet 8 inches wide by 5 feet high. In other words, it is very similar to my Scion xA -- it is about 2 inches wider and 5-6 inches taller. Here are photos of the model so far:
http://img.photobucket.com/albums/v7...d/DSC_3921.jpg http://img.photobucket.com/albums/v7...d/DSC_3914.jpg http://img.photobucket.com/albums/v7...d/DSC_3912.jpg http://img.photobucket.com/albums/v7...d/DSC_3907.jpg http://img.photobucket.com/albums/v7...d/DSC_3903.jpg http://img.photobucket.com/albums/v7...d/DSC_3896.jpg http://img.photobucket.com/albums/v7...d/DSC_3894.jpg So, what do you think? I need to find some 1" diameter (2 feet scale) wheels -- my intent is to have them fully inboard and skirted. The fronts would have to be slightly articulated i.e. the skirts would move when turning sharply. |
Model airplane wheels.
Looks like the Boxfish. regards Mech |
now take up smoking and get some clear pvc tubing and a low speed fan for your wind tunnel.
inhaling not required |
I don't like it (or the Boxfish). If you're making an electric car, why not make it sleek and beautiful? The last thing electric cars need is more Steve Urkel nerdy stigma.
I think it is sleek and beautiful! :p I have to make it practical, too. I'm hoping to have 5 seats, and the driver will sit in the center front (like the Pillbug). And I like sitting upright -- I detest low reclining seats in cars.
A good pickup on the Boxfish inspiration -- actually, it is between the Boxfish (Cd = 0.19): http://www.designboom.com/contempora...mimicry/06.jpg and it's earlier model (Cd = 0.095): http://www.carbodydesign.com/concept...s-bionic/3.jpg The front is more from the Boxfish, and the covered wheels and the general shape is from the blue model. I'm leaving off the sharp pointy bits in the very back. The batteries (and supercapacitor?) will be under the floor, and interior floor will be flat. I'm going to try to use hub motors. There are other things that I am trying to work out, and I'll post progress photos and updates as I go along. P.S. Who is Steve Urkel? |
a little box-fishy
it does look somewhat like the boxfish,, but i like the boxfish and would buy one if its ever made avalible at a resonable cost, if your shape is a low drag one,, go for it i like it!
Bah, EVs and aeromodding should be a nerdly pursuit. I love my Insight, and the people with whom I choose to associate accept my Insight.
Neil: If you photoshop (or paint) some tires, doors, and glazing onto it, we'd get a better idea of what you have in mind. As it stands, the front glass looks a little hard to manufacture, and the lower rear glass... has a crease in it. :P What kind of usage profile, specs, budget, and battery chemistry do you have in mind? Were you going to use a donor chassis? |
Hi Robert,
I'm going to add wheels and possible paint it -- after I also shape the bottom and work out some more details. I would build the chassis from scratch, I think -- I've only done a little welding, but my brother owns a MIG setup and my nephew is a trained welder. For batteries, I'm assuming lithium iron phosphate, ans if I can work it out, I'll use a supercapacitor, too. At first, I might use a single AC motor for front wheel drive, but if I can find 'em, I'll use some hub motors. |
I hope you have some idea of the time and expense involved in making a car from scratch, to a standard that other people would ride in it. Homebuilt aircraft are much simpler, on average, and usually have plans and other support available. 10% of them are completed by the first builder, 10% by the second, and 10% by the third, with 70% being scrapped before use. Most cars have more man-years just in design work than you have available in your whole life. There are a few exceptionally talented builders; have you been astounding people with your other projects? Energetically, custom cars only pay off if they have features that get copied in production cars.
i can't do it... did you see that motorcycle with the streamline shell? i couldn't even make time to make that little thing.
i doubt mine would look at sweet as the original. |
I say, find a compact car whose handling and interior you like. Then buy one that was in a rollover, sell the interior, and attach your body over its. |
Hi,
I've added wheels, and contoured the bottom somewhat: http://img.photobucket.com/albums/v7...d/DSC_3946.jpg http://img.photobucket.com/albums/v7...d/DSC_3934.jpg http://img.photobucket.com/albums/v7...d/DSC_3928.jpg http://img.photobucket.com/albums/v7...d/DSC_3958.jpg The wheels are 27mm diameter, which is 25.5", and they are ~9" wide in the tread. I bought them at the slotcar track I frequent -- hence the white letter sidewalls... |
I love the rear wheel fairings. The approach and departure angles look plausible, too.
You need to murder out those tires, son. Daytona don't make no LRR's. :p The back still looks very large to me. Can you get away with more aggressive angles, a narrower rear track, rear outrigger suspension (my favorite option!), or a boattail? |
c;mon... buy some smokes and blow on it. or you know.
The rear is ~4'-6" wide, and virtually the same from the ground to the "peak". My biggest mistake so far is the bottom of the rear should not curve up -- it should be straight back, and have a crisp corner, like the sides and top.
I can't narrow the back unless it extended farther back, and the top slope is already limiting the usable headroom. I'm going to try to draw it and see how I can arrange the seats, etc. BTW, I'm thinking that the front wheel skirts are articulated by connecting them to the steering rods. The wheels will be able to move a small amount without moving the skirts, but at low speeds, which is the only time you steer up to the lock, the skirts kick out as required. The bottom could be a truncated circle, that rotates with the skirt. |
race car builders build cars from scratch, and some people do it fast, but these cars are very much unrefined as mentined and expensive if you dont know how to do it, you should make freinds with a racecar fabricator to at least pick his brains, getting a donor car as suggested sounds like the best idea, but it needs to be a full frame car,( not a unibody) so that leaves out a whole bunch of cars, i wanted to do a complete body mod on my echo but when you go cutting on a unibody with all those crumple zones and cad designed stress points you could easily weaken the wrong thing, great looking design though.
Here's an update -- I've started drawings of the CarBEN concept EV:
http://img.photobucket.com/albums/v7...arDrawings.png Next, I need to fit the major components into it ... and start to work out the structural ideas. FYI: drawing foreshortened curved surfaces is not easy, and I've fudged things a little. The dotted arcs around each of the front wheels on the bottom view are the pivoting sections, that move along with the outer skirts, when the wheels are turned sharply. I'm going to check the angles to make sure that they "comply" with known limitations. The wheels are ~25" outer diameter, so, the rims are 15" diameter. The rear wheel track is ~8" narrower than the front wheel track. The wheels are dashed when they are hidden within the bodywork. The bottom slopes up towards the back (also shown dashed behind the wheels strakes). The sides are more convex than my model is, and the wheels are closer to the sides than they are in the model, as well. This makes the strakes more asymmetrical. |
Something like this for a donor car would get you a long way with little effort. Also an antique which woud mean (at least in VA) you would not have to deal with much regulatory issues or inspections.
Saab : eBay Motors (item 290395979898 end time Feb-05-10 14:38:28 PST) I have a 71 Karmann Ghia that I was thinking about messing with, but I kind of lost interest, until I can get something going on my IVT. regards Mech |
Hi Robert,
Hi,
I've been do a little work on the drawings for my CarBEN EV concept: http://img.photobucket.com/albums/v7...WithSeatsB.png The seats are intended to be stretched mesh over frames, so they will be as thin as possible, and breathable for good cooling. The arrangement of the seats are still not settled (nothing really is!) -- the idea is to have the driver sit in the center and to have everybody enter through the rear hatch (which includes much of the rear fascia). The battery pack I've drawing is 6" thick and is 4 feet square (8 cu. ft). The angles are from the highest and lowest points to the trailing edge, and then tangent from the trailing edges. The frontal area is 25.543 sq ft (see the 1 foot grid on the front view in the drawing) -- and IF the Cd is 0.10 (higher than the blue clay model of the Boxfish concept it is based on) -- then the CdA = 2.5543 sq ft! Wow, if I can pull that off... |
The M-B Bionic concept illustrates that a blunt front is okay, but a low drag car needs to have a very small rear. That explains a large part of the difference between the Cd=0.095 clay model and the Cd=0.20 concept car, which had a relatively large rear. The rest may be due to adding door handles, wipers, ground clearance, and panel gaps. CarBEN's rear is much larger than that of the clay model. As a percentage of frontal area, it's somewhere between that of the Cd=0.25 Insight and the Cd=0.188 EV1.
Traditionally, tall vehicles need a wide track for stability. However, going electric and mounting >1000lb of batteries below the floor gives you the option of being tall but not wide. See the Commuter Cars Tango for an example of this. If you can find a way to make your car a foot or two narrower while staying within your project's goals, you'll end up with a much lower Cd, and a much much lower CdA. Such a car should be called the Trout, instead of the Boxfish. A conventional streamlined car has very long overall length to taper its roof down to meet its floorpan. Instead, the Trout is very narrow to achieve a similar Cd with a shorter overall length by having its sides taper inward until they meet. The Trout does well in a wind tunnel, but less well in a crosswind. Thanks for the thought-provoking thread. |
Neil, how much reference material do you have to go from besides the one picture of the blue mock up model that MB made ?
I've been looking for more images of the original model ( the blue one ) but haven't seen any. |
I think that this project embodies the spirit that Ecomodders have.
When car manufacturers tease us with vaporware concepts that they never really intend to build .... we just build the damn thing ourselves :) ! |
Neil,
Great idea, great work. When you make the car, better make molds of the body work so you can sell them and recoup your R&D costs. If you built around a readily available, older chassis, you have a better chance of interesting others in your design. It looks to me like he fifth seat is causing some serious design problems; headroom, legroom, etc. Is it really necessary... maybe a fold down jump seat instead? Without it you could tighten up the vertical dimensions/angles back there and would still have a useable trunk/cargo volume. |
Thanks for your responses, folks! I've been thinking a lot more about this project, and I will be writing things down and doing some more drawings. Here's what I'd like to do to check/refine the aerodynamics:
Build a scale wind tunnel! For the 1/24th scale of this model, it would be pretty easy --and I can even use my belt sander (upside down on the floor of the tunnel) to mimic the moving roadway, and to spin the tires... Is this something I can find on Instructables? How would I make a scale sized smoke trail device? |
This will be an Open Source project!
Very important: This will be an Open Source project! I want to have others be able to use anything, or all of the ideas that are used for this. It's the principles of how and why this design can work that is important.
Here's what I mean by Open Source -- essentially the same as open source software, applied to engineering: 3 posts tagged ?open source information? - NeilBlanchard?s Blog on Vox Quote:
The trouble with small models is that to keep the Reynold's # the same, the wind speed is increased in inverse proportion, and you'd be getting into sonic effects, (perhaps including those of the neighbors. )
Thanks Bob -- I'm sorry to hear that! Yes 24X the air speed would be a big challenge! I guess that is why the pictures of the Mercedes scale models show them in a fluid tank? :-(
Okay, a few more points: yes that one picture is the only one I've found of the blue model with wheels. The (slightly revised) frontal area of the drawing of the CarBEN concept is 25.814 sq ft. and the area of the rear fascia is 10.166 sq ft. so the taper is ~2.5:1. Also, please note that my drawing is approximately 4" narrower per side on the rear fascia, than the wood model is. |
I've been working on the drawing of my CarBEN concept EV:
CarBEN 1/24th scale wooden model of EV - Updated 13 Feb 10 - Vox http://img.photobucket.com/albums/v7...V-Drawing1.png If anybody would like a copy of the DWG file (or the DataCAD AEC file) I'd be happy to send it to you. I hopefully will be starting on the 3D CAD model soon. |
I suppose now is the time for criticism, before the design solidifies.
Have you made a chalk-and-lawn-furniture mockup of the seating arrangement? It's very unconventional, and I wonder how well it works. There is too much unutilized width in your vehicle. You should be able to lower your roofline a few inches by placing batteries below everyone's chair, and below nobody's feet. Regarding the driver's on-center location: that's great for a race car, and it's good for side impact safety. However, road cars traditionally place the driver at the left side of the car (in LHD countries) so he can put the left wheels exactly where he wants them. A notable exception is driving in the alps. If cliffs are more of a concern than traffic, sitting on the RHS is preferred. I am not an expert, but it looks like you need a LOT more room between the front bumper and the driver's feet. Check out your Scions. I bet that distance is just under a meter. Since your car will not be run through real or simulated crash tests, and you may have trouble managing zones of different stiffness, better to err on the side of caution and go with a 1m crumple zone. I'm making several assumptions there about what you're going to do with the vehicle, and how safe it needs to be. A vehicle which is novel and awesome can get away with poor crash safety, as long as it's something you drive slowly, carefully, and seldom. Something daily driven in traffic and/or snow, needs to be safer (says a man whose Insight has been in two fender benders in four months). If I can get my CFD software running, I'd be happy to run your 3D CAD model through it. Quote:
Wow!
I don't know anything about actual aerodynamics or design but this is a very, very interesting thread. Neil, power to you for thinking big and good luck. I will be keeping my eye on this for sure. |
...human shoulders are much wider than their heads, hence, "wrapping" the body slightly closer to passenger heads will greatly reduce "unused" width as well as overall body cross-sectional area.
...and, don't forget about "left-hand" drive people, so unusual offset seating might not be popularly acceptable. ...I *DO* however, like the *idea* of articulating front wheel covers, but wonder how well they might actually perform? Ok at lower speeds, but at highway speeds will they "balloon" and "parachute" and thus cause more drag than they're supposed to reduce? Nevertheless, the *idea* is excellent. ...with advent of airbags, one wonders *WHY* the auto industry hasn't gone back to tubing frames for weight and structural improvements? Nice thing about a tube is that it can simultaneously serve as a conduit for wires, hoses, cables, etc., heck even as exhaust piping! |
My hope and intention was to has the wheel skirts be sealed, even when they are pivoted out -- the inner fender, as it were, would slide out and maintain a closed cover. So, it would not be a parachute.
...oops, that's what happens when the reader doesn't "read" the writers' mind correctly.
A brief update: Here's a Sonex airplane that my friend Mike Smith is building from scratch:
Sonex -- The Sport Aircraft Reality Check! I think the 4-cylinder 80HP engine weighs ~130 pounds, and the dry weight of the whole plane (including the engine) is 570-620 pounds. 22' wingspan, and the fuselage is 18' long. +6G and -3G in a 440-490 pound structure is great! This construction method is pretty straightforward. It uses 0.025" and 0.032" 6061-T6 Aluminum sheets, and some aluminum plate and angle stock -- and thousands of pop rivets. http://www.sonexaircraft.com/images/...ayout_6677.jpg What my friend did is he drew the patterns full size in DataCAD (which the way you always draw things!) and he plotted them out full size (you can choose any scale for plotting) and he used spray adhesive to stick the paper onto the aluminum sheets. Then he cut them out, drilled all the holes, deburred them, clamped them in wood forms (two halves cut out of OSB board and wing nut and bolted) and used a soft plastic hammer and a pair of special pliers to pleat the flange around curves. He's spent about 500 hours and he has almost all the components made. He's spent ~$1,600 on stock and ~$900 on tools. Doing a similar process on a car would not seem to be all that hard. Oh, and I'm continuing on the drawings -- I'd like to be able to test the aerodynamics of it before committing it to reality...or at least before building a working chassis! |
...sounds like the old "build-it yourself" MIDGET cars that were advertised in Popular Mechanics magazine.
Okay,
I added a bit more to the "shoulder" of the sides, and I sloped the side windows inward at the top, and the Area is reduced by about 0.9 sq ft; to about 24.976 sq ft. I also will extend the lower center front out to give some more crumple space, and to make it less blunt aerodynamically. I'll post the revised drawings soon. |
Here's the new drawings:
http://img.photobucket.com/albums/v7...V-Drawing2.png The front bumper has moved 5" forward, and the front wheels have moved 3" forward. I've drawn the section at the highest point of the roof, and this is superimposed on the front view. The steel protection bars are shown in the section, and the larger circles are the cutouts in the web of the aluminum rib. |
I would like this to be an open source project. By that I mean, that if anybody would like to contribute, or take what I have and run with it -- as long as you keep me up to date, then great.
Here's a photo of the revised 1/24th scale (1/2" = 1') wooden model and the drawings that I've been working on: http://img.photobucket.com/albums/v7...d/DSC_4205.jpg Here's a start on the 3D model -- I have drawn what could be aluminum ribs that would be part of a monocoque chassis (very similar to the way acrobatic airplanes are made): http://img.photobucket.com/albums/v7...tions4-5-6.pnghttp://img.photobucket.com/albums/v7...-rendering.png The rib on the right is at the highest point on the roof, and they are 1' apart (for modeling purposes, anyway). The large rectangular hole in the floor of the two is for the battery pack. The battery pack is the 4' square by 6" deep shaded rectangle on the drawings. At this point, I'm thinking it would be better and faster to have my wooden model 3D scanned and have a mesh/surface model made. Does anyboy have any experience with this? Here's an outfit that can do it for ~$100-200: 3D Scan Services LLC - Affordable 3D Scanning and Reverse Engineering Services, but I'm hoping to find a place that is much closer to Massachusetts, where I live. CarBEN Concept EV An Open Source Project http://img.photobucket.com/albums/v7...h_DSC_4193.jpg Project Outline Design and build an uber-efficient electric car; that has very low aerodynamic drag, as low weight as possible, is designed with good safety and crash protection, is practical to drive (i.e. it is not too big and has nimble handling), and I would like it to carry 4-5 people. By the way, the reason I chose the name CarBEN: it is a play on the word carbon (I want to not waste any), and the change in spelling are my initials backwards... :-) http://img.photobucket.com/albums/v7...xfishModel.jpgThe basis for the aerodynamics is an early clay model of the Mercedes Bionic car (aka “Boxfish”) that was itself based on the boxfish. The tested coefficient of drag (Cd) of this model was an amazing 0.095 (Automotive Engineer PLUS - Mercedes-Benz) and it seems like a great place to start! The later Bionic car had a Cd of 0.19, which is still very good; but the open wheels and wider shape in the back are the primary reasons for the increase in drag. Another design that inspired a lot of the CarBEN design is the Schlörwagen – a very aerodynamic design from 1939. My idea that will allow the wheels to remain covered, and therefore (hopefully) achieve a Cd nearer to the blue model than to the Bionic car, is to have articulated front wheel covers that move with the wheels in sharper turns. I'll get more into the details of how this could work later on. To achieve low weight, I think the ideal structure would be carbon fiber reinforced plastic. But this is difficult for me to work with, as I have no experience with it, and I think the prospect of making molds and the fumes, etc. is daunting. I've also considered welding a steel tube chassis, and then make either a fiberglass or aluminum body. But I think this would be heavier, and while I have access to a MIG welder; it is not as good as an aluminum monocoque chassis. I got the idea for how to do this from seeing a friend who is building an airplane from scratch. It is a 2 seat acrobatic capable, and the dry weight (including the 4 cylinder 80HP engine) is between 570 and 620 pounds. I think the process he is using, which plotting out full size templates, and then forming the 6061-T6 sheets into the ribs and the skin; using wooden forms – makes a lot of sense to use this method to build this car. Aluminum is fully recyclable, it is not dusty, has no fumes, and only requires a small bandsaw, a pair of “pleating” pliers, a soft hammer, and riveting tools. If I start with a 3D CAD model and drawings generated from that, the templates will be accurate. The resulting chassis should be lighter than I could manage with steel, and it forms the body at the same time. Starting with the Sonex airplane (Sonex -- The Sport Aircraft Reality Check!) and its weight of 620 pounds (~130 pounds for the engine is included in that) – the 22' wingspan and 18' long fuselage have roughly similar surface area to my CarBEN design and so it should weigh about the same (490 pounds). The AC electric motor and mechanical drive train are maybe a little heavier than the plane's engine; say 150 pounds. Add the four wheels, brakes, and the suspension (say 250 pounds) and the battery pack (say 400 – 600 pounds), the seats (which will be quite light – more later) and miscellaneous stuff will add 150 pounds. The the total vehicle weight could be in the 1450-1650 pound range. I would be very happy with anything under 1800 pounds. The first order of business is to get the overall chassis to be as low drag as possible: I can loft a 3D CAD model from the wooden model I have made, but I think it would be better/faster/cheaper to have the model 3D scanned and use the mesh model for virtual aerodynamic testing. A program that can do 3D flow would be very important to check the form and to adjust it to lower the drag as much as possible without making it impractical to drive. i.e. I'm 6'-4” and I want to fit comfortably, and I need to fit my family. For the safety considerations, the first thing I am doing is making the structure surround the passengers, and in order not to weaken it with doors, like most cars do. Like all design decisions, this involves some compromise, and I have been considering what some other designers have done: both the VW 1L and the FVT eVaro have canopies (like a jet fighter airplane), so that the structure around the passengers is continuous; the compromise comes in inclement weather, as the roof is not over the seats. Another car design that uses an unusual door and entry method is the Loremo; the entire windshield and hood hinge up (from the front) and you step over the side and pull the door back down in place. This also involves the steering wheel and column hinging up and out of the way with the door. The passengers get in through the rear hatch (and they sit facing backwards). So, the initial door concept I am hoping to use is: in order to maintain a wraparound structure for safety, there is a single door in the rear of the CarBEN. It has two parts: a sloped hatch that is approximately the back 1/3 of the roof; it lifts up but remains (mostly) covering the opening from precipitation. The rear fascia of the car is a pair of small hinged doors that swing out. This is a a good a place as any to put in the drawing:http://img.photobucket.com/albums/v7...V-Drawing4.png To get in the CarBEN, people would step up to the floor, and then turn to close the back doors, and the walk up the “aisle” to their seat. (This hopefully explains the staggered seat placement?) The overhead hatch would be closed – the details need to be worked out. If this door idea is not workable, or involves too much effort, then the fallback solution is to have conventional side doors – but I would use 3 or more latches (instead of the usual one) so that the door has 5 (or more) points of attachment (instead of the usual 3) so that the opening is not unduly weakened, and the passengers would be well protected from side impacts. The other key solution to getting the CarBEN to work within a very low drag chassis, is the idea of articulated front wheel skirts (see the top, side and bottom views in the drawing). These consist of a ¾ moon panel on the bottom (shown with a dotted line) and another ¾ moon panel on the outside of the front wheel (also shown with a dotted line). There is a slot in the bottom panel where the wheel protrudes out, and there is an inner fender and curved panels that keep the wheel covered even when the steering is all the way to one lock or the other. The suspension motion of the wheel does not move the skirt assembly – the tire moves up and down through the slot and within the inner fender. The whole assembly pivots on grooved rollers around the edge of the bottom panel (see the small circles on the bottom view drawing) and a pivot at the top of the inner fender. The steering pushrods are connected to the skirt assembly, and swing it with the wheel when the steering angle is sharper than needed for highway driving. So, at high speeds the aerodynamic shape remains unchanged, but at low(er) speeds when sharper steering angles are needed, the panels move to maintain clearance around the wheels. This is the biggest compromise made in the Schlörwagen design – they made the front wide enough to enclose the wheels even when they are at either steering lock. The Schlörwagen is 2.1 meters wide (6'-11”) which has a large affect on the area and hence the drag (CdA) and the car is wide; making it more difficult to drive. It also means there would be more body roll than would otherwise happen. The battery pack (the 4' x 4' x 6”rectangle) should fit in the floor, between the four wheels. The AC electric drive train is a typical front wheel drive system; which will provide the best ability to have regenerative braking, to regain some of the power. I intend to use a super capacitor in parallel with the battery pack, which allows higher current to be absorbed from regenerative braking to be absorbed, and it can provide bursts of high current for acceleration, greatly reducing the battery load during charging and discharging, while driving. The folks at ChargeCar (at Carnegie Mellon) are working on enhancing this kind of system with “smart” programing that uses data from your commonly driven routes (using GPS to locate where you are driving) and elevation data to “anticipate” how to best manage the regenerated power, and to make the best use of the supercapacitor; as a power cache. (to be continued) |
