Carbon fibre wheels.
Leading on from the "Aluminium Radials" thread on this board.
In the 1970's Citroen experimented with Carbon fibre wheels for their SM model. Sadly little progress seems to have been made since then. Does any one know of a source for these for road cars? And why do F1 , Indy cars etc not use them? Cheers , Pete. |
I read something on this awhile back... there are a few companies (at least one) overseas that make CF wheels, but they're not available for street use.
I *think* it has something to do with torsional loading, etc, that makes them more likely to decay and be damaged in short order vs. alloy wheels. Even if you could get them, and get them imported, it's still illegal to run them on the street, as they're not D.O.T. Approved, and probably won't be any time soon. I'm sure there is a concern over the wheels being made of "fabric" or something. This, of course, applies to US DOT, not Aussie. Have no idea about foreign (to me) countries. |
I've been eyeing up a set of carbon fiber wheels:
http://www.zipp.com/_media/images/dy...ubular_set.jpg http://spidermouse.us/images/smilies/wink3.gif |
Do those have tires on them?
I saw somewhere... (might have been a joke) latex compound bike tires... very low weight rating, but they were supposedly LRR tires for bikes.. |
Most "carbon" bicycle wheels are only carbon fairings attached to an aluminum rim. The properties of the aluminum make it less likely to self destruct in a pot hole or something like that. After seeing a true carbon wheel colapse after a 5mph collision with a dog in the Tour de France there is no way I'd want one on my car.
As far as sturdy bicycle wheels I like American Classic's line of aero rims. The difference in aero is negligable for us mere mortals, the wheel is lighter, and costs a lot less. |
Back in the 80's Carroll Shelby was building some great little hot rods based on fwd Chrysler platforms. The Shadow based 89 CSX had fiberglass reinforced plastic rims called fiberides. They were lighter than the alloy wheels but never really took off and to find a 89 model with those is EXTREMELY rare considering that they only made 500 of the Shelby CXTs. The wheels were fine for road use, but on road couses many of our Shelby/Dodge Auto Club members have found that the centers start to melt causing the lug holes to soften up and wallow out!
89 CSX-VNT Info |
there are carbon wheels out there for cars, very rare, race only. there are more options for carbon wheels for bikes and motorcycles |
1 Attachment(s)
... given this characteristic of CF to delaminate (essentiall shatters into shards and dust, much like glass would) it is much too risky to use it for the wheels of an open wheeled race car capable of speeds in excess of 300km/h. Given the high potential for contact of all sorts in open wheel racing, I can’t imagine seeing a car traveling at those speeds and having it’s wheels delaminate from an impact and essentially turn into dust leaving only the rubber behind. Carbon fiber is beyond EXPENSIVE. :eek: Up to $59 per yard. Carbon Fiber/Graphite from Aircraft Spruce The CF wheel in the attachment weighs 6.1 lbs. and cost $4000 per wheel. :mad: |
fiberides
Its to do with the tensile strength of carbon fiber and the low coefficient of thermal expansion
Wheels get hot they also get shock so you want a strong material that has a bit of give in it, carbon fiber is just too stiff to be reliable in the application of a wheel. When the wheel gets a heavy impact and the tensile strength is exceeded the wheel will explode rather than get bent like a normal alloy. |
Saw a gimicky looking thing a while back that was basically weights on springs you attach to the wheels. At low speeds, the mass is near the hub for better acceleration. At higher speeds, the mass is closer to the rims for better momentum. Interesting concept and apparently, on the right course, can increase average speed. But back to carbon fiber: carbon fiber failing is pretty high on the FAIL scale, far more so then the metal alloys. |
Faster you went, larger the rear sprocket would get... only in final gear though, and it had extra sets of teeth that would fill in the gaps to keep the sprocket "round" so the chain wouldn't leap. |
E-mail me your name, address, and phone number. I will put a feeler out on the two national forums and send your info ONLY to those that have rims available. ataylorracing@comcast.net :thumbup: |
I meant the fast Shelby/Dodge drag racers, not road racers.
Thanks to all who posted.
There are some valuable points for further consideration there. Pete. |
Hi,
The Britten V1000 had handmade carbon fiber everything -- the wheels were constructed in a "skin & bone" method, with carbon fiber: http://static.panoramio.com/photos/original/5718288.jpg The whole bike was just 138kg (305 pounds): Britten Motorcycle Company |
carbon fiber also isnt good with "shock" nor is it flexible.
i hear alot of the monocoque design cf bikes disintegrate after harsh use. but i know they make carbon fiber sidewalled tires. not cheap stuff, and they only come in low pros i believe. |
i saw a guy repeatedly pick his cf bike up over his head and throw it to the ground in a fit of anger after flatting on a first lap escent and losing contact with the pelaton - the bike took it all in stride awesome material i ride with many people and unless it's a big crash, i've never heard of frames going i have witnessed cf fork failures but that's a pretty demanding job i have a set of these wheels, but have been too busy to try them out http://www.pezcyclingnews.com/photos...no/toposet.jpg |
