Carburetor tuning!
So I've finally put my Ninja 250 back into service after nearly 3 years of downtime. Don't ask. :p
Anyway, before I put it up, I had added K&N pods, gone with 108 mains and 1 shim under the needle. Stock with the airbox is 105, no shim. I've been accelerating with wide throttle openings between 3-4K, and today I took out the shims. Power below the point the main jet opens seems a little reduced, the engine falls off much faster when dropping the throttle, letting the clutch out while revving needs to be done a little more carefully to avoid stalling the engine and the engine still cruises fine, no hiccuping. I don't have any method of measuring my air/fuel ratio, so I'd like to know from those who tune carbs if the above sounds like its running lean enough to cause damage. |
What you are looking for is the BASE RING.... that is the ring on the bottom of the plug that the ground strap (the arm) is welded/soldered to. What you want to look for is a full turn of darkness all the way around the outside of that ring. If its not all the way around, the bike is lean. |
I'm no expert but I've been recently buggering around with modified intake and carbs on 2 stroke scooters. The bigger main jet/pod mantra is oftern bandied around as a good thing, but for cruising I think not.
I have found results confusing, to say the least. Try sliding a sock over the pod, try different thicknesses of fabric, 2 socks, thinner socks. This will restrict air flow AND improve filtration. Try no pod or filter, this will increase airflow. Going to 108 is not much of a jump. Often I go from 65 to 80 on a 50cc. (I have one bike with a 120!) My feelings are that increasing fuel and air flow create starting and running issues including bogging at low revs. Done right, top end is improved, but I fear that all else suffers. If you cruise at small throttle 90% of the time, you may piss around for ages with no gains whatsoever. Many modified scooters get sold by owners who have bought all these go fast bits, but never got the machine to run right. I race around on my 50cc, and am often at a speed, much higher than previously attainable. My guess is that with a thin sock or 2 things will improve for general cruising and top output may see gains too. Duct tape to cover some of the pod, stays on for months too, and you can fine tune your air intake by adding/subtracting strips of duct tape. Then of course there is the intergrating of other important factors like intake manifold exhaust valves timing plug heat range....however that all said, a pod and main jet up size is a good cheap power upgrade only if you ride to the tuned settings. Namely, increased top end. If you cruise at small throttle 90% of the time..... you keep pulling the carby off, chop needle heights and jets and socks for ages and ages with little gains..... Sock it to them and see what happens, thats what I've just done and come away thinking too much air isnt always good unless you go a whopper main jet and ride flat out always. |
Yay, nay? |
And I have not read the K&N thread yet. |
I really dont want okay comment....But your method is not correct. A only slightly opened throttle does not allow for upper speed jet testing, you need to go faster!
If your bike power and overall rideability improve with a kids sock, you are too lean. If cold running requires more choke than before, you are too lean. High speed lean is the damage problem, so your testing has to be done at high speed. Sometimes rather than too lean or too rich, it comes down to too much air for the matching restrictive exhaust.... Socks are a good diagnostic tool. Really! Putting them on and taking them off is easier than pulling plugs, and not only gives you feedback re the state of the mixture vrs ambient and engine temperatures, ( as a spark plug 'chop' does)but also allows you to fine tune your CORRECT intake restriction... for that season/time of day.... I often leave them on as they fine tune an air/fuel mixture just perfect. In cold weather I use a thicker sock! Initially have socks with you when you ride, and change them around until you find the bike is at its best. Take a screwdriver and adjust slow speed mixture and idle. Eventually this will be the correct mixture that your bike runs best at. Usually takes around 15min on a hot motor, pulling over and increasing or removing restrictive fabric from the air intake. If the bike never improved with the thinnest most stretched out sock, it is too rich. But with your present changes I doubt it. Pods with their higher flow will lean an engine, requiring much larger jetting or more fuel. Hardly an economy move. |
LOL, that is funny. I ditched my airbox because I couldn't troubleshoot the carbs with it on, and have these glorified clamp on window screens in place now which obviously do not allow enough restriction with standard jetting.
Anyway I've been bodgering cut up paper house furnace filter around them (and spraying them it with paint for fine tuning), an actual sock would have been much easier. |
I may try the sock idea. As for going high speed, I don't plan on doing a whole lot of that, I plan on riding around between 3K and 4K, since I work at night, there's minimal traffic on the road, I drive slower.
