Old 08-03-2022, 02:48 AM   #1 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
Old Saabs freewheeling features
Do any of you have current or past experience with these old Saabs, the 96s or the 95s or the Sonett? I have read that perhaps regular civilian type people could get in the mid-40s miles per gallon with these if it is the Sonett. I could imagine that one of us from the Forum could do maybe much better? I guess the system was a little bit fragile, as apparently some people had trouble with them to the extent that they literally welded them so they wouldn't have effect? Would be curious to hear some thoughts on all this . The V4 sounds like an interesting engine. I know that some engine parts must be hard to obtain at least here in the states.
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 60MPG so far 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!![SIGPIC]
Old 08-04-2022, 02:20 AM   #2 (permalink)
Wait... Was the freewheeling device fitted to Ford-powered Saabs too? I knew it was a standard feature of the DKW-powered ones.
Old 08-04-2022, 08:34 AM   #3 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
I drove several v-4 Saabs while working at an import shop in the 70s. Yes they had the one way clutch. It had a lever you could move and convert it to a conventional setup. In the one way position you used the clutch to start and stop but you could upshift by breaking torque. Of course there was no engine braking and you could coast in gear just like neutral. The engine would drop to idle and would catch back up with throttle. I would imagine that it could be fragile with abuse.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
Old 08-04-2022, 12:12 PM   #4 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
V4 equipped cars had the freewheel too. Yes it was fragile.
Old 08-04-2022, 12:21 PM   #5 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Was this Saab freewheeling clutch for all gears?
The VW Lupo 3L had a freewheel for the top gear only, and could not be engaged/disengaged at will, iirc.
Old 08-04-2022, 01:23 PM   #6 (permalink)
Are we talking about like a 3 speed manual overdrive free wheel from the 50's?
Old 08-06-2022, 11:08 AM   #7 (permalink)
wdb
lurker's apprentice
It affects all gears.
