Old 11-04-2015, 10:01 PM   #1 (permalink)
30 mpg Ranger Supercab
In June I bought a 2011 Ranger XLT Supercab with the 2.3 4 cylinder and 5 speed manual. It's 2wd. At 60 it gets 30 mpg. At 70 it gets 27. I drive mixed in town and rural delivering pizza getting 20mpg, so I'm not often at highway speed. I'm thinking of just adding a flat bedcover with treated plywood. It would be nice to keep the snow out of my trucks bed. Would I see an increase with the bedcover?
2011 Ranger white 2wd 2.3 5sp Supercab 4.10 axle
2009 Ranger white 2wd 2.3 5sp longbed 4.10 axle
2004 Ranger white 2wd 2.3 5sp longbed 3.73 axle
The Following User Says Thank You to Flyinghippo For This Useful Post:
BamZipPow (11-05-2015)
Old 11-05-2015, 05:03 PM   #2 (permalink)
bedcover
here is the drag table for GM's bedcover which includes data for a full cover.
The C-10 pickup they tested had around Cd 0.535.You can see the change the cover provided.
On a percentage basis,the best you could probably see is this percentage change.
Your Ranger is much 'cleaner' than the C-10,and the gain from the bedcover might be less.
Old 11-05-2015, 05:19 PM   #3 (permalink)
Sorry I'm confused looking at that attachment. I'd make a full length bedcover.
aerohead (11-05-2015)
Old 11-05-2015, 05:32 PM   #4 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
The drawing shows that a full length cover is worse aerodynamically than one that covers only the last 50%.
I'm not coasting, I'm shifting slowly.
Old 11-05-2015, 05:42 PM   #5 (permalink)
I'd rather keep the snow out it will be a full length cover.
Old 11-05-2015, 06:15 PM   #6 (permalink)
At the bottom right of the table,you'll see data for the 100% length (full) cover.
The drag coefficient change around 0.032
Starting at Cd 0.535,the full cover got GM to around Cd 0.503.
That's a 5.9% drag reduction,and good for about 3% better mpg.
That's as much as you could hope for basically.
Old 11-05-2015, 06:28 PM   #7 (permalink)
3%= then maybe 1 mpg on the highway and almost nothing in mixed driving. At least I'd keep the snow out. If I had more $$ I'd make an aero curved sloping back topper out of lexan or similar.
