EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Cd 0.38 (https://ecomodder.com/forum/showthread.php/cd-0-38-a-32984.html)
aerohead 10-24-2015 04:15 PM
Cd 0.38
Just to illustrate some of the variability of shapes with identical Cd
http://i1271.photobucket.com/albums/...titled1_24.jpg
http://i1271.photobucket.com/albums/...d2/06-2826.jpg
http://i1271.photobucket.com/albums/...titled19_3.jpg
http://i1271.photobucket.com/albums/...titled1_19.jpg
http://i1271.photobucket.com/albums/...titled9_19.jpg
http://i1271.photobucket.com/albums/...titled8_19.jpg
Cd 10-24-2015 05:30 PM
I just don't understand.
How can the Smart car have the same Cd, yet have such a massive wake ?
The wake of the Z-28 is tiny in comparison.
Are the vortices just more controlled in that design, or what ?
freebeard 10-24-2015 10:04 PM
Cd (a dimensionless number) is what's being asserted. But I'm wondering for an equal A (area) does the height/width ratio have any impact? The Template would be .5, my car closer to 1. The Smart could be over 1.
This is based on the sides having twice the taper of the top.
aerohead 10-26-2015 05:08 PM
how can
*The car is highly detail optimized,with minimal turbulence before the tail truncation.
*It has extremely good sectional density,displacing the air nicely with it's leading edges for complete flow attachment,and gradual reduction in cross-section allowing separation-free flow to the truncation,with perfect pressure recovery.
*It's fineness ratio is adequate for Cd 0.38.
*While it DOES have a relatively large wake,the base pressure is higher due to the careful contours and pressure recovery upstream.Just like a 2015 Ford Econoline which shares the same Cd.
http://i1271.photobucket.com/albums/...titled9_15.jpg
*It's 'Stromform' nose is of the lowest drag.
http://i1271.photobucket.com/albums/...Untitled24.jpg
*It's the only car with a proper K-form truncation.
*It has zero-induced drag penalty.
*There is essentially zero vorticity.
*The base pressure of the Z-28's wake will be the same as at it's early separation point,way forward on the back slope.Very low pressure! Quite a penalty!
aerohead 10-26-2015 05:21 PM
height/width
Kamm and Fachsenfeld tested this at the FKFS and the short answer is no,it didn't make a difference.
They varied the width of their airfoil-shaped model from around 230mm,to 1,000mm,holding the height constant,and recorded the same Cd, on a frontal area basis.
Any car of any scale will have an identical Cd as long as Reynolds number is accounted for.They call is dynamic similarity,or verisimilitude.
The tunnel velocity must be such that a turbulent boundary layer is guaranteed.
kach22i 10-26-2015 10:24 PM
I had to look that one up.
http://ecomodder.com/forum/showthrea...orm-28260.html
This thread will cover the 'K-form' which is commonly referred to as the "Kamm-back",which is a misnomer due to the fact that it was invented by Baron Reinhard von Koenig-Fachsenfeld.
I had the same reaction as "Cd", still amazed.
aerohead 10-27-2015 02:44 PM
same reaction
Aero's a funny thing.So far,the best for cognitive dissonance is this comparison,both cars Cd 0.311
http://i1271.photobucket.com/albums/...titled10_1.jpg
http://i1271.photobucket.com/albums/...titled16_4.jpg
:D
skyking 10-28-2015 01:10 PM
thanks Phil. This all gives me hope that my Kamm efforts are the way to go.
Cd 10-28-2015 03:50 PM
:D
But ...but ...it has a pointed nose. ;)
UFO 10-28-2015 03:57 PM
I agree. I still think a flat spoiler would look cooler, or at least strange in a striking way, but I bet you get better results with your Kamm ideas.
