EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Cd or weight? (https://ecomodder.com/forum/showthread.php/cd-weight-38708.html)
Taylor95 10-26-2020 05:47 PM
Cd or weight?
Imagine that you are buying a new vehicle to modify for fuel economy. You plan on using this vehicle for 50/50 city and highway driving. You have narrowed your choices down to two vehicles which are virtually identical except for the following:
Vehicle A has a 10.0 Cd advantage over Vehicle B.
Vehicle B weighs 1000 lbs less than Vehicle A.
Which one would you choose, and why?
CigaR007 10-26-2020 06:28 PM
I would be inclined to say that it is easier to reduce the Cd.
1000 lbs is a lot of added weight and you would be making sacrifices to shed a portion of it.
jakobnev 10-26-2020 06:44 PM
This man has a dog and a mother in law that don't like each other!
How do I know?
Elementary my dear Watson, the dog likes to have it's head out of the window, and the mother in law is a bit on the heavy side.
And he has to choose only one to bring on the vacation trip!
freebeard 10-26-2020 07:27 PM
Vehicle A has a 10 point Cd advantage over Vehicle B.
IIRC 10 points is 0.10 Cd.
It's all relative. Beginning Cds and weights are...?
Taylor95 10-26-2020 08:28 PM
The question is purely hypothetical so actual values do not matter.
However, Vehicle A could have a Cd of 0.25 and weight in at 4000 lbs.
Vehicle B could have a Cd of 0.35 and weigh 3000 lbs.
freebeard 10-26-2020 08:54 PM
Yes, but relative values do.
Thanks for describing the size of the ball-park. Power to weight? (not trying to be a troll)
Taylor95 10-26-2020 09:54 PM
Assume both vehicles have the same engine. An average car can put out around 180 horsepower to the crankshaft.
freebeard 10-26-2020 10:19 PM
I going to go ahead and side with JulianEdgar: testing.
aardvarcus 10-26-2020 10:29 PM
I would vote lower cD. Careful driving to minimize brake use can minimalize weight penalty. Inertia isn't the enemy until you convert it to heat.
I would also assume in real life that weight could buy you extra utility.
freebeard 10-26-2020 10:59 PM
I can't choose. You have one vote each right now.
Less weight means better 60-foot times but better Cd is going to look better. :confused: Intangibles.
