Go Back   EcoModder Forum > AltModding > Saving@Home
Old 08-23-2010, 09:37 AM   #1 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
DIY Grid-Tie INVERTER??
Found this today, Grid tie Inverter
"Warning: This system could drain a car battery in a few minutes."
"Advantages: * Wide range of DC voltage from 3->50V."
At first glance, it looks way too simple to work (as a GTI)..
I can see no way a low DC voltage source (like 3v) can add power to the grid.
I wonder if this thing is actually a battery discharger?
Any engineers out there care to comment?
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 08-23-2010, 07:35 PM   #2 (permalink)
I don't understand how it can work either. I plan to design and build a grid tie inverter from scratch, but I first need an oscilloscope to debug the design.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 08-23-2010, 08:25 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
maybe it only pushes on the grid when the phase is below the rail? pretty cheezy if so
Old 08-23-2010, 08:53 PM   #4 (permalink)
I looked at the AC current flow in both directions. The diodes on the gates make the triacs work like plain old diodes.
If I'm right, the 4 triacs and 4 diodes make up a simple full wave bridge Rectifier..
Having 120 hz positive pluses appear on the left side of the cap, doesn't seem like it's going to do much magic.
So, a full wave driving a series cap & battery.
Depending on the size of the cap, it Kinda looks like a battery charger, but the battery is connected backwards..?.
So, does that mean it's a battery dis-charger?
If it is a dis-charger, does the battery's power end up on the grid??
For sure, I would connect the AC via an isolation transformer..
No sense getting killed..
And maybe a Variac adjustable autotransformer to feed the isolation transformer!!
Cheers,
Rich
Old 08-23-2010, 09:03 PM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
If I understand it, it is not a true inverter, it pushes on only part of the sinewave (i.e. when it is less than battery voltage) and thus distorts it, perhaps to the dismay of the rest of the grid.
Old 08-23-2010, 09:39 PM   #6 (permalink)
If the capacitive reactance is low, the + pluses will be felt on the - battery terminal.
The + battery terminal will be connected back to the "minus" side of the AC.
It seems like those two voltages would add. Positive peak + battery.
Like to batteries in series.. -+ -+
So maybe, it's not the just a part-time push. If the battery is going to add it's voltage to the whole up-down cycle of each pulse.. No distortion.?.
So, a 12v battery would try to push your 120AC up to 132AC..?.
But, it's limited by the amount of current that can be carried by the cap...
Cheers,
Rich
Old 08-23-2010, 10:28 PM   #7 (permalink)
dcb
needs more cowbell
dcb's Avatar
mebbe, dunno. the triacs are like $6 apiece so not the most expensive experiment in the world.
BTA25-600BW STMicroelectronics Thyristors - Diacs, Sidacs, SCRs & Triacs
Old 08-24-2010, 07:17 AM   #8 (permalink)
And of course, since it isn't UL listed to the appropriate standards, it can't be legally connected to the grid, whether it works or not.
Old 08-24-2010, 08:23 AM   #9 (permalink)
Maybe if you used only UL listed parts.?.
I wonder if those 1930s insulators I see on some power lines are UL listed??
Some of those street lights look like they were installed in the 1940s..
Must have Grandfathered in.?.
Cheers,
Rich
Old 08-24-2010, 08:47 AM   #10 (permalink)
dcb
needs more cowbell
dcb's Avatar
The more interesting question is if it distorts the grid or not. Show that it works, then worry about the law, maybe we can play dominoes on sunday in alabama again?
DIY Solutions to Honda Hybrid Battery Problems (Insight, Civic, IMA) RobertSmalls Hybrids 265 06-18-2020 02:15 PM
I want to get to the bottom of this ethanol killing my mpg Nerys General Efficiency Discussion 175 08-16-2012 08:32 AM
Inverter coolant pump bwilson4web Hybrids 15 08-03-2010 04:40 PM
DIY solar - to - grid tie shovel Saving@Home 10 03-30-2009 09:37 PM
EVs to stabilize grid? Frank Lee Fossil Fuel Free 11 02-13-2009 12:56 AM
