EcoModder.com
-   Hypermiling / EcoDriver's Ed (https://ecomodder.com/forum/hypermiling-ecodrivers-ed.html)
-   -   Is this cheating? (https://ecomodder.com/forum/showthread.php/cheating-5366.html)
trikkonceptz 10-02-2008 11:57 AM
Is this cheating?
My work commute is as unchanging as they get, 50 miles each way, same path same traffic patterns unless there is an accident.
My one way commute using driving techniques usually yields 46mpg by the time I get out of the vehicle. This happens driving 55mph, 40mph in the city. I have 2 highway segments divided by 2 city segments.
Now last night I drove home @ 65mph, 40mph city commute, 55mph on 2nd highway stretch & 40mph in the 2nd city stretch and when I got home the scangauge still read 46mpg.
Is this possible because of the distance I cover? 46mpg seems to be the limit currently with mods, technique and weather. I just do not know what 46mpg avg means. I would think that my average would be lower considering the higher speed on one leg of the commute.
Chime in please.
Ford Man 10-02-2008 01:31 PM
The best way to check this for accuracy is to try these speeds everyday for 2 or 3 tanks and figure it using the miles divided by gallons method then go back to your old speeds and check it the same way. The scan gauge is a good tool, but it's not always perfectly accurate. It does seem that you would have lost some FE by driving faster, but I have read of others claiming to get better mileage at 60-65 than at 55 although it's never been the case with me.
trikkonceptz 10-02-2008 02:00 PM
Nor me, my best FE is @ 55mph unless drafting ... I'm just curious if the distance I drive is a factor? Knowing that no matter how much farther than the 50 miles I drive will not result in better FE, I wonder if there is a distance where I reach optimal FE then after that its all maintenance.
IndyIan 10-02-2008 03:16 PM
Do you mean that your first 5 miles has, for example, a trip average of 32 mpg, and then the trip average gets better as you go?
I guess the best trip average you could hope for is slightly less than your best 55mph instantaneous MPG if you don't pulse and glide and are driving on a flat plane.
I like the trip MPG function as it shows how bad your mileage is on short trips, and the cost per trip function. Costs me a dime to get out of my driveway!
Ian
TestDrive 10-02-2008 03:26 PM
A couple of things that may contribute.
Maybe the ECU's open loop fuel map leans out enough at the higher rpms to give better FE?
In any case, the engine is bound to warm up sooner at higher rpms allowing the ECU to go into closed loop sooner. And you're bound to get better FE in closed loop.
PaleMelanesian 10-02-2008 05:27 PM
I find that after 10-15 miles, it levels off. The first 5 miles are bad, 5-10 is ok, and 10+ is cruising time.
BlackDeuceCoupe 10-02-2008 06:06 PM
I guess I don't get it, trikkonceptz :confused:
What are you asking? Cheating at what?!?!?
I imagine my commute is very similar to yours. I drive 3 miles from my house to the freeway. Then 40 miles of pulse n' glide freeway driving to the turnoff for work. Then 3 miles from the freeway to work. I usually take the same route, yada, yada, yada.
I seem to get better FE @ 70 mph (4400 rpm) than I do @ 55-60 mph (3000-3500 rpm). And, I'm strictly going by raw numbers, if you will, e.g. not using a SG or whatever - just topping off my tank every two days and using the trip meter, a wristwatch calculator, and the EM fuel log, to compute my mileage.
The thing is, I don't like to drive that fast, even if it gives me better FE!
My dumped rice rocket *looks* fast. Driving fast is just asking for a speeding ticket!
Anyway, what is your concern? I don't get it...
Do you *feel* like you're cheating by driving too fast - too far - doing too much freeway driving - not enough city driving?
LoL!
I don't *feel* guilty because I get world-class FE, nor *believe* I'm cheating... :cool:
Is THAT what this is about - you *think* you're inadvertently rigging the results?
trikkonceptz 10-02-2008 06:12 PM
Here is my question, I gues in SAT test format .. LOL
My drive is comprised of 4 legs;
-Home to Hwy - Seg A
-Hwy to Crossroad - Seg B
-Crossroad to Hwy - Seg C
-Hwy to Wok - Seg D
I tested this on two nights heading home; Usually the distance Seg D to Seg A results in my Scangauge reading a 46mpg Avg.
The other night I drove Seg C @ 65mph, by the time I exited the Hwy I was at 40mpg. The crossroad segment added on another 2mpg, then I got on to seg B which netted me 45.8 by the time I exited. Once home I had 46.1mpg.
Looks like I can cheat on one segment, make up for it on another segment and still net the same mileage. But is it really?
BlackDeuceCoupe 10-02-2008 06:21 PM
Why do you *feel* that you're cheating on one segment?
Who/what are you cheating - cheating death by driving too fast?
That's what I don't get... :)
trikkonceptz 10-02-2008 06:44 PM
No .. hehe .. cheating my overall tank average ... if now I do 55hwy 40city and get 46mpg, and I can achieve the same results by doing 65mph for a time then 55mph for a time and still get the same read out on the scangauge, is the scangauge accurate? Or am I using more fuel?
BlackDeuceCoupe 10-02-2008 06:50 PM
I see... ;)
Do you ever fill your tank and reconcile it to your odometer/trip meter - or strictly go by your SG?
trikkonceptz 10-02-2008 06:58 PM
I never rely on the scangauge .. I always go by my mileage. Which lately has been about 1mpg off from the scangauge.
BlackDeuceCoupe 10-02-2008 07:06 PM
It doesn't sound to me like you're cheating - you're just compensating...
It's like, I'll race someone - feel remorseful - and drive like a Granny for a few days.
dcb 10-02-2008 09:57 PM
It is one of those "this might be to good to be true" kind of things. I don't blame you for being suspicious. There are many possible sources of error :)
http://ecomodder.com/forum/showthrea...html#post53360
Sandy 10-03-2008 10:50 AM
With my underpowered civic,
I originally tried the slow route,
holding up traffic the climbing hills.
The results were good, but not as good as when I found that at 60 to 65 the results were better.
At the higher speeds, I can coast or DWL better at the higher speeds as I go over the 20% of my commute on some slow rolling hills.
The tall hills still get me back to DWL at lower speeds but once at the top it's better with higher speeds.
The only guess I can come up with is the anemic engine really has to work to get going but once it rolls the aero is quite good.
Daox 10-03-2008 11:27 AM
I'd drive one way and try it for an entire tank to make sure. The SG is probably right, even though it does seem odd. However, I'd double check it.
trikkonceptz 10-03-2008 02:44 PM
I'll try it with the next tank, it should make for an exiting test. This tank will continue with 55mph.
