EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   check out my taped hub caps! (https://ecomodder.com/forum/showthread.php/check-out-my-taped-hub-caps-6770.html)
modmonster 01-14-2009 08:19 PM
2 Attachment(s)
this was easy to make look nice!
modmonster 01-14-2009 08:20 PM
duct tape is king. im gonna try it on my tricky textured plastic wheel arches next.
wikityler 01-14-2009 10:06 PM
Duct tape degrades quickly in UV (sun) light. The adhesive dries and becomes powdery.
http://profile.ak.facebook.com/objec...69424_5288.jpg
brucey 01-14-2009 10:27 PM
I used foil tape on my alloys and it turned out fine. Been there several weeks without a problem. I have since removed one spoke because it was ripping around the valve stem. And I figure at least now I can say its got plenty of brake cooling blah blah.
With them fully taped up though I saw 0.9 mpg difference average according to some scan gauging.
bgd73 01-14-2009 10:41 PM
crazier than a cereal bowl on a sube carb!
wagonman76 01-15-2009 12:44 PM
I used packaging tape to attach the coroplast discs to my trim rings, then painted over the discs and tape. Theyre still holding up just fine. I installed them at the beginning of August and drove it till the end of November.
modmonster 01-15-2009 07:54 PM
maybe some kind of varnish coating would help the tape fight UV
cfg83 01-16-2009 02:25 AM
modmonster -
Hrmmmm. I wonder if there is a more "UV durable" version of duct tape. I like the foil tape idea, but the duct tape is a better color match and I think it's "flexiness" (can't think of a better word) is more compatible for the shape of your wheel cover.
CarloSW2
PaleMelanesian 01-16-2009 09:02 AM
"Spar" varnish is designed for boats, and has UV inhibitors built in. It still won't save the adhesive from deteriorating, though.
Bicycle Bob 01-17-2009 10:45 PM
Counterintuitively, clear duct tape is more durable in UV.
