EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   cheeeeeap tachometer - harbor freight - $20 (https://ecomodder.com/forum/showthread.php/cheeeeeap-tachometer-harbor-freight-20-a-5488.html)
thefirebuilds 10-10-2008 03:57 PM
sure its garbage, but better than a dummy light.
Harbor Freight Tools - Quality Tools at the Lowest Prices
bhazard 10-10-2008 05:51 PM
Yea and the $15 vac gauge dont sound too bad either.
Dust 10-11-2008 11:20 AM
Not bad looking i must say
almightybmw 10-13-2008 04:43 AM
now if they only had a cheap electric speedo I could ditch the cable driven one...just need to find one that matches my signal output, or converts it.
thefirebuilds 10-15-2008 11:13 PM
for $20 this worked great, but i damaged my speedo in pursuit of installation. The tach is decent though.
thefirebuilds 10-15-2008 11:14 PM
electronic bike speedo that uses a hall effect gate?
almightybmw 10-16-2008 02:07 AM
the trans has an electric output on the speedo gear, I just need to find out what pulse it runs at, and match it to an electric speedo. I'm a fan of the analog gauge, even though the led display would be easier to implement. I have several EE friends, I'll sit down with one of them and see what we can build to convert the gear signal to what a commercially available gauge (like autometer) would require.
cmittle 10-16-2008 08:42 AM
How does this tach know what your engine rpm is? I would like to have a simple tach around the garage that could maybe use an inductive pickup from a plug wire so I can check things like the lawnmower or my moped engine or car engine from in the engine bay.
ATaylorRacing 10-16-2008 03:51 PM
The tach from Harbor Frt is only for 4, 6, or 8 cyl motors. If you have an O' Riellys around you can get a iEquus tach that uses an inductive pick up wire that is clamped to the coil wire. Just had one put on my 3 cyl Geo Metro yesterday. The cast here was under $75 with tax for a white faed one that has various color bulb covers to change the lighting color at night. Part # 8068 was mine...it was the lowest cost one that would work with 1-12 cylinders.
ac7ss 11-07-2008 05:45 PM
It looks like the one you linked to is Discontinued.
I switched to GPS for my speedometer a few years ago when the old speedo died in my VW van. It was cheaper than a replacement speedo.
