Chin spoiler and tire spats
Ive done a TON of searching and lurking around here and other sites and have read the great success stories from running front air dams and the likes. I want to mod my 93 Escort, but I want to make it so it looks like it came from the factory, so no big bumpers or anything. I would love to make a simple chin spoiler and maybe some tire spats to break the wind around the front tires, but after reading up Ive seen alot of back and forth on what would be ideal design wise and what would make things worse. Is there a solid answer as to what I should aim for, or is it pretty much up in the air? Angles, height from the ground, shape ideas to shoot for? I appreciate the wealth of knowledge on this site and hope to be able to add to it myself one day!
Matt |
Thanks for posting the question, I'm looking forward to the responses as well.
Here's an article that addresses tire spats. It's specific to that model, but should be useful as a general guide for others as well.
Autospeed Modifying Under-Car Airflow |
spats
On low-drag cars,the wheels and tires can constitute half the drag.
You might consider going beyond spats and consider actual canoe-fairings as you see on aircraft,high-mpg concept cars,university mpg record cars,and university and corporate World Solar Challenge cars. These devices will pay the largest dividend and are not as elusive,design-wise, on a car-to-car basis.:) |
Ive read the Autospeed article a couple times and love the info, funny thing is I like the idea of the stock spats on the Prius LOL.
California, do you have any pics posted up with of your spoiler and spats? Ill do some searching today and see what I can find, but Ide love to see more! Matt |
Here is the pic. The lower grill block has been rebuilt, so that there is just one opening, left of center, directly in front of the radiator and ducted to it. Soon I plan to fill in both upper and lower blocks, fiberglass them, and make smooth surfaces, but I need more time: http://ecomodder.com/forum/member-ca...ing-airdam.jpg Hope that helps. I might redo it too. I want the ends to come closer to the front wheel wells. Lawn edging is pretty cheap and I have plenty extra since I had no choice but to buy more than immediately needed, so the cost will be nil. |
Excellent, that does look slick!!! I couldnt find any link like you said, but do you have shots of how the spats looks with the front spoiler? I was lookin at using the garden edging, but my buddy has some really light, very durable material at his shop we could use. Its plastic layers with a this layer of aluminum sandwiched in I believe, we could cut, bend and shape it however we please. I might try his stuff but if it doesnt work, garden edging it is.
Matt |
California98Civic,
Nice job on the mods. I would easily take them as being factory if you had not pointed out the changes you had made. Peter. |
Lawn edging, what a great idea!
Sometimes tire spats that seem as though they would help the Cd count, really don't do much of anything.
When these spats were tested on this '80 Camaro, they didn't do anything for the Cd despite shielding those wheels sticking out into the wind. http://image.hotrod.com/f/10214175/1...side_spats.jpg Car Aerodynamics - A2 Wind Tunnel - Wind Camp Tech Theory Here, Eaker is examining the stock Z28-type side spats, which did not alter the Cd but added 40 pounds of rear downforce. He thought they may be more helpful in yaw but says testing 0 degrees to the airflow gives you 75 percent of the data you'd need at slight yaw. We also tested the Moon discs, which reduced drag by two to four counts. The farther the wheels are from the outer edge of the fender, the less the discs matter. View Related Article Read more: Chevy Camaro Aerodynamics Side Spats Photo 8 Aerodynamics can be puzzling sometimes. Truly unpredictable ! |
The area of the wheel sticking out in the wind is enormous ! I would have thought the spats would have dropped the Cd quite a bit. While we are on the subject of that car, just look at the huge gaping wheel wells around that back tire ! No wheel skirts, yet a .201 ! And stock door handles and misaligned window trim as well ! That car LOOKS like an aero nightmare. |
Like that boxy yet sleek old Lexus sedan, whatever that was.
spat
The Trans Am Firebird used 'leading' streamlining to clean up the flow for this region of the body. |
I took a crack at some innitial planning and designing last night at a buddies shop. We did a ton of thinking, messed with a few different materials he had layin around and eventually got to work on puttin together a simple "prototype to test out made of aluminum. I didnt want to go too low with the stuff and scrape it all the time so I went 3" below the stock bumper which is enough to cover all the "nastiness" as we call it thats previously left hangin in the wind LOL. We didnt have enough time to finish but the design looks alot like a stock chevy chin spoiler that is only in the front and doesnt wrap around. Im not sure I like it very much but might test it out when we finish and see what happens. Im thinkin I might grab some of that lawn edging and do one more like I wanted, where it wraps all the way around the bumper like the lower chin on the boxy Jettas and Golfs. We messed around with tire spat ideas as well, real simple like the old Prius used to have but will finish the spoiler first. No pics yet, but when I get the bracket together Ill post some up and get yall to critique it!
Matt |
rear
In the absence of an airdam and rocker panel extensions flush with the outside edge of the tires,the flow to the rear spat could be real 'trash',negating its effect. |
It sounds as if you mean that the front airdam keeps air from colliding with the tire, spoiling an opportunity for the spat to function, yet the wheel covers ( Moon discs ) functioned as they did, so plenty of air was getting to that area. |
Ok, ive still got the first chin spoiler we made, and could finish it up and install it to try out, but now I have a question. What would be better, chin spoiler and tire spats, or do a front underbody tray from the bumper to the front suspension and then some spats along with that? If the tray would be better I wouldnt have to worry about the ground clearance but then again I can make the spoiler a bit higher to deal with it if needed. I appreciate any advice!
Matt |
that
I am dyslexic
Good grief! My apology to all. Is this the Camaro with the aluminum nose which is completely sealed? |
there's a good reason you're puzzled,it's my stupidity!
My brain was interpreting the image with airflow from the left to right. tru tried to set me right and it went right over my head. Is this the Camaro with the aluminum nose which extends to almost ground level? I need to know exactly which car this is.I apologize for the mix-up.( you guys need to keep a close eye on me!). |
Thanks Matt |
Escort
Today's NASCAR noses( without the splitter) would be a good example for a nose remodel for healthy airflow if you wanted to take it that far.The lower portion could be a flexible material to deal with curbs and parking hazards. After that you could appraise your situation and go from there. |
Thanks! I didnt take a pic, it was too dark and we never finished it. I believe we will reuse the brackets and run somethin more flexible like what you stated, maybe some garden edging or similar. I got to thinking about the underbody pan, but if you look at the front of my car, there is alot of "ugly" that sticks out below the bottom of the front bumper so my belly pan would have to come down abruptly, then smooth out in order to cover it all up. A front splitter or apron would cover it...then maybe make a pan connected to it? I need new struts for this thing so Im thinkin bout loweing it an inch or two as well down the road.
Heres a picture of the "ugly" under the bumper. http://img.photobucket.com/albums/v1...ightResto4.jpg Matt |
http://media.scenedaily.com/images/5...r-Nascar-2.jpg james |
Source : Lexus LS400 http://upload.wikimedia.org/wikipedi...00_UCF10_I.jpg http://upload.wikimedia.org/wikipedi...tone_Pearl.jpg The next generation LS430 had an even lower Cd of .26, and .25 with optional air suspension, which lowered the car around an inch. http://images.thecarconnection.com/l...00005822_l.jpg Despite LOOKING sleeker, the current generation ls460 is also .26 ( I suspect the wheels have to do with the higher drag ) Sources : LS | Detailed Specifications http://the-grayline.com/wp-content/u...s460-awd-1.jpg LS430 : http://carblueprints.info/blueprints...ls430-2003.gif LS460 : http://www.the-blueprints.com/bluepr...s460l-2008.png |
NO WAY that thing is that sleek! Looka dat hood/windshield junction! :eek:
Not only does the car have the barn door flat front end, but it has the original misaligned moulding around the windshield, stock unshaved door handles, huge gaps everywhere ( look at the wheel wells ! ), no belly or skirts, etc ! It blew my mind, but it was tested in a wind tunnel by a guy that did the aerodynamics on the EV-1 ( How ironic that the car has almost exactly the same Cd as the .19 of the EV-1 ) |
I really think it would be great to invite the fellow that runs the tunnel there to join us for a few questions sometime ! :thumbup: |
I wonder if that tunnel would say my Coupe has .19 too? :p
I posted a picture of the actual car in question and ask for any other ideas. I think a chin spoiler california civic's will be the first step, along with ditching the front plate bracket. Tire spats for front and rear tires will also be looked at. My question with the spoiler is, how low should I go. I dont wanna make it rediculously low and scrape it on everything, so would makin it just low enough to cover up the "ugly" under the bumper work? Matt |
The Camaro does apply, in principle.
If you take the chin spoiler alone, then generally lower is better. (See pic of Camaro above) Mine is 2" off the pavement and rubs everywhere. It is wide enough that it does the job of front tire spats as well. It made a large difference for me. I used the lawn edging as shown previously. It lasts about one year if you are rubbing constantly and is much more durable (because it will spring back when bent) than the Aluminum Sandwich. Get the lawn edging and screw it in and see what happens, cut it down a bit and see how your mpg or coast distance changes, don't overthink this and don't worry about what people think as you expierement. Once you have a result you like, you will be able to live with the look. Everyone that asks me about my rear wheel skirts, I tell them that I think it looks goofy and I don't like the look, they then have a puzzled look, then I tell them it adds 3mpg and they begin to understand... |
LOL, very true about the looks deal, but I made a challenge to try and keep it looking OEM, as if it was an option off the showroom floor, or perhaps a tasteful aftermarket mod. I love to test and tweak and test some more so Im all over that...altho I must say, this car already coasta like a mofo...I can even imagine what Ide do if it would go further with less effort LOL. I might try out a couple different setups as well, front underbody pan, front air dam, both etc.
Matt |
rocker area
Even though it has an abrupt corner it's embedded within a favorable pressure regime,forcing attached flow. Once past the rear edge of the front wheels there should be nothing but turbulence all the way down the rocker panel area,rendering the leading spat inoperative. Also,since the rear of the Camaro is 'open',air cannot pool within the rear wheel wells as would happen more in the 'production' car,and will dive into the void immediately. The MOONs do offer a solid surface for the air to flow over.On the Trans AM Firebird I think they were good for a 0.024 drag reduction compared to a stamped steel aspirated wheel. |
