City-EL - any warnings?
These German made 3-wheelers have been around for years. I am in the process of getting one here in CA.- licensed and ready to go. It has already been beefed up from a 36V to a 48V. It is a '93, but it looks like the same design now made.
I heard too much negativity and disappearing service in my town about the Xebra, but this has ZERO service! Any dire warnings about this vehicle? |
Besides parts, it would probably be classed as a bike out here
But originally I meant motorcycle since its a 3 wheeled motorized transport. |
The new ones will do 40 MPH. I'd just be a little leery of the tricycle design. Sudden turns at those speeds could cause it to nose over to one side since the rear track looks kinda narrow.
Would you mind giving us a ballpark $$$ figure? New ones are 8,000 euros ($11,400). I'm cool if it's none of my damn business! |
1 Attachment(s)
Sad thing is - it ain't cheap, so I won't be saving any money at all. A shade under $6k. Cheaper than most velomobiles, but I will be eating beans and rice a long time. The Aspire will probably go on Craigslist- but it is not even worth $1K with the seats missing. |
There is a local EAA member (JW) here that has one and there are some others not far away. JW just bought a Sparrow so he sort of quit driving the "L". He found the 36V "L" was not very adequate for traffic. I think he called it a rolling speed bump.
JW hasn't had it long and it had CA registration so the title transfer was easy. Insurance can be an issue with some companies. The one you have may not go for it. Tires are model specific and not easily obtained, JW's big nightmare so far, so plan ahead. I'll send JW this url. Neat ride and 48V probably makes a big difference.:thumbup: Need I say drive defensive! EVDRVR |
Thanks for letting me know EVDRVR. Before lowering the top speed due to the 20 mph limit on the E-Pod, that trike would rattle my fillings out. It still rides hard; but not AS hard! It has fatter tires, more open-cell foam, and a little more foam insulation. some people wonder why I wear a helmet in that- I hit a tree root and {BLAM} know why I do! Hopefully the City-EL is not so violent!
Chris,
JW read the forum and says it is a small world. He figures you are buying the "L" from Scott? If that is correct JW will also plans to be at Palo Alto tomorrow afternoon. JW has figured out a way to use a different tire on the L (a size that is available and not so $$$) but it requires a suspension mod that he designed. The original shock spring set-up is pretty soft and the newer bigger tire rubs without stiffening the rear end. I've seen the mod and it is a nice coil over with a mounting bracket. A definite improvement. I'm pretty new to this foum so if i figure out how I'll send you JW's email address. EVDRVR |
That's the one! Scott is picking me up to go to the Palo Alto event! VERY small world!!
Copyright ©2000 - 2021, vBulletin Solutions Inc.
