Old 04-12-2011, 05:17 PM   #1 (permalink)
Black Beauty - '13 Hyundai Elantra
Engine braking
Saves brakes, but worth the wear and tear on transmission?
Does it increase or decrease fuel economy?
Any other thoughts? (I've heard both answers to both questions. I'm curious to see if anyone can provide a convincing well-reasoned answer to either.) I of course realize answers may depend on the situation somewhat.
Old 04-12-2011, 05:40 PM   #2 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
the only time i engine brake (by down shifting) is when i have to brake hard for some reason. other than that i sometimes use it to maintain speed going downhill (by simply leaving it in gear and letting off the gas completely), but that is all.
Old 04-13-2011, 07:15 AM   #3 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
There is no wear and tear on the transmission by using engine braking properly.
It's just lifting your foot off the accelerator.
Many people will downshift frantically early in the process, but that's not the point.
Lift your right foot or cancel the CC.
Shift down when the revs have already dropped down to a point where you're hardly slowing down anymore.
Repeat.
Depends on what you'd do otherwise.
It's more efficient than driving under load longer, then slamming on the brakes.
It's less efficient than coasting (even with the engine on).
Old 04-13-2011, 09:17 AM   #4 (permalink)
Ok that makes sense because the people saying it's hard on the transmission were assuming early downshifting. However, even "gentle" downshifting should put more strain on the transmission than coasting, right? More shifts, each one coming in at a higher rpm than you would want to shift at if you were being gentle with the clutch.
As far as fuel efficiency, the person who told me the opposite of that told me that when engine braking the wheels "drive" the engine, thus using less gas than at idle. Is that just a bunch of baloney then?
Old 04-13-2011, 09:23 AM   #5 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
THE person was referring to dfco, wherein fuel is cut when certain conditions are met. It is not universally applicable.
Its efficiency depends alot on the skill of the operator.
Considering that using gears to decel, or hold speed, case by case, is basically the norm for driving instruction, even in automatics, and these transmissions don't have abnormal wear/failure patterns, Id chance a bet that you're not doing anything harmful, and your friend is probably regurgitating something he heard out of context, in an attempt to sound like he has some knowledge on the subject.
Old 04-13-2011, 09:24 AM   #6 (permalink)
if the engine is below a certain RPM (which varies by vehicle) it will inject fuel regardless of the status of the transmission or throttle. i have yet to find the injector cutoff point on my Jeep, heck, i'm not even sure if it has one.
The Following User Says Thank You to Joenavy85 For This Useful Post:
Christ (04-13-2011)
Old 04-13-2011, 09:28 AM   #7 (permalink)
Usually 1100-1300rpm.
Old 04-13-2011, 09:30 AM   #8 (permalink)
i've had mine at over 2000, in gear and decelerating, throttle closed, and the injectors were still operating
Old 04-13-2011, 09:33 AM   #9 (permalink)
Dfco also depends onfactors like engine temp, on time, etc. It is entirely possible that your Jeep just "no gots".
Old 04-13-2011, 09:39 AM   #10 (permalink)
that's true, like i said "i'm not even sure if it has one" i wired in an indicator LED parallel with one of the injectors (it's fused and i have extensive electrical background to repair if required) and it always stays lit while engine braking , though i haven't done much over 2000 RPM, maybe the ECU only shuts off some of the injectors??
