Civic VX spark plugs ZFR4F-11 ZFR5F-11
Honda recommend the Civic 92-95 VX to use spark plugs ZFR4F-11 and ZFR5F-11 in hot climate or continuous high speed driving.
Has anyone try using the heat range 5 yet in this hot summer climate? If not, I might be willing to try it once I get my mpguino installed. |
I tried the ZFR5 in my 98 HX, not good, ZFR4 good.
Use the colder 4's. lean burn = less heat, so a hotter plug may misfire by not getting up to temp. If they made a 3, that might be worth trying, otherwise stay with the 4's.
Correct spark plugs for my VX
So I've been away for awhile struggling to resolve a sudden 10 mpg drop after a tune up. I will share more about Pearl's journey to 50 mpg, but...
Could the fives the dealer sold me account for that severe of a change? I don't know have a record of the existing plugs that were replaced. It would make me Very happy to solve this frustrating and expensive conundrum. Are there also special ignition wires for VX? |
From my understanding the plugs all moved 1 number higher to account for ethanol in gas.
I run autolite iridium 5244 plugs and I'm very happy with their performance Zr5f are the recommended plug per the parts store. I have noticed that gap size decreases and heat range decreases with ethanol to make up for lack of combustion And yes, ngk tr555 in the camaro for daily driver, ngk tr6 for nitrous. Higher number is colder |
Zfr5f or 4?
The dealer i just talked to said both of these plugs (zfr5f & zfr4f) are ngk iridium and that they are the exact same plug other than the stamp.
I am trying to re-gain 10 mpg lost after a tune by a guy unfamilar with the special nature of the VX. I also have a 97 HX to double check. |
You better check around because those numbers do not match any ngk iridium plugs that I could find. Those are standard plugs, not iridium, they are copper core. I have an HX and that's what I run. The cost about 12.00 for 4 and you would never get iridium for that. The ngk numbers 4 & 5 are heat ranges 5 being the colder plug, 4's best for lean burn.
Both plugs are copper core but the plug looks polished like a platinum plug but the core is copper |
Thanks you're right, they are indeed Not iridium tipped (the dealer was wrong-surprise).
They are copper and nickel tipped according to the ngk website. I actually have the 4's. If there's an actual mpg increase in an ngk iridium, please recommend. Otherwise, I will keep these in the VX & HX too. No such thing as a tune? Ok fine. :) I didn't proof my work. |
