Old 10-05-2009, 04:46 PM   #1 (permalink)
No power to fuel pump '93 metro
There is no power getting t the fuel pump relay. I checked all the fusees under the dash and the ones next to the relays in the engine compartment. Is there a fuse I am missing? or does this sound like a short. The fuel flow stopped when i was driving 30mph in town and it was abrupt.
Old 10-05-2009, 10:24 PM   #2 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Was their any recent work done to the car? You cannot hear the fuel pump kick on at all?
GeoMetroforum.com - got mpg?
Old 10-05-2009, 11:22 PM   #3 (permalink)
No sound at all. I checked and there is no power getting to the relay. I am just don't know that much about electrical problems yet. I must be missing something simple. I think this car was in a flood at some time before i bought it, I have found rust in strange places and corrosion in some of the connectors. where does power go before the relay in this car/
Thanks a ton for any help!
Old 10-06-2009, 06:54 AM   #4 (permalink)
Hi-Tech Redneck
I will post up a wiring diagram tonight for you.
Old 10-06-2009, 11:03 PM   #5 (permalink)
Hi-Tech Redneck
Old 10-12-2009, 01:22 PM   #6 (permalink)
Thanks a lot Johnny, I am going to go and get on it right now!
Old 10-12-2009, 06:45 PM   #7 (permalink)
This is getting fun
well, I keep blowing a fuse. I checked and there is continuity from the computer to the relay and from the relay to the fuel pump. So I am not sure why I am blowing that fuse, maybe a bad ground?Would it be a bad idea to cut the existing ground wire and re ground the pump directly to the body?
Would i be blowing that fuse because of a bad relay? still doesn't explain why I was not gettin power to the relay( blown fuse), but why does the fuse keep blowing?
I am tired and proly not making complete sense...
Thanks for any help!
Old 10-12-2009, 08:26 PM   #8 (permalink)
Hi-Tech Redneck
It would never hurt to add a known good ground.
Heat Pump Temp Lockout Settings to Gas Backup RH77 Saving@Home 3 03-11-2012 09:41 AM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 10:35 AM
Help needed - 999 MPG instant - 93 Metro rmcelwee OpenGauge / MPGuino FE computer 6 05-25-2009 07:38 AM
93 Geo Metro timing belt check? ncsteve EcoModding Central 0 05-09-2009 10:52 AM
Geo metro 93 vss and injector leads GeoGreg OpenGauge / MPGuino FE computer 4 09-13-2008 06:45 PM
