Old 07-06-2011, 03:08 AM   #1 (permalink)
Mustang - '98 FORD MUSTANG COUPE
Question about latest mpguino setup
Was looking through the opengauge source folder and saw the new mpguino diagram (v1.3). It uses the atmega328 chip, but has a few extra connections
A1
A2
RX
TX
PB2
PB3
AR
These were not on the previous diagram so I was trying to figure them out. I did some looking through the forums to find info on this new diagram.
I was able to find this page
hxxp://ecomodder.com/forum/showthread.php/differences-between-prebuilt-mpguino-code-official-code-14751.html
In which a member states there is no arduino dependency.
So I'm assuming that chip can just be programmed outside circuit and put back in, hook up vss-injector-battery-ground and you are good to go? Or is it a bit more complicated?
Old 07-06-2011, 05:21 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
I program them with ISP, technically they do not need programming outside, but I hate explaining programming, but yes it is completely doable thousands upon thousands of people have figured out how to program these chips. Yes it can be a little complicated, but all those pins were pulled out specifically for experimentation by the adventurous.
Old 07-06-2011, 12:33 PM   #3 (permalink)
Got it, so this is just like the ISP circuits used in programming PIC chips, super useful. Not asking for programming tutorial, I know it's like the fish and fishing pole story.
So before I even get started I still need some sort of programmer to get the code on there. So I will need something like
USBtinyISP
USBtinyISP - Inexpensive USB AVR Programmer
or even simple parallel programmer?
Arduino - ParallelProgrammer
So just out of curiosity, what would be an example of what you could do with those extra pins?
