Old 09-17-2022, 04:40 PM   #1 (permalink)
Chief Cook & Bottlewasher
Xterra - '13 Nissan Xterra Pro-4X
90 day: 18.63 mpg (US)
New, but not New
Hello ladies and gentleman, I've been a user of ecomodder since 2012 or so. Three different vehicles and I've learned a lot from reading the forum though I don't post very much if at all through these years. EDIT: I see I've posted 72 times including this one!
The reason for this intro post is that I have a question that I couldn't really find an appropriate forum to post it.
Question: Is there a way to export all fill-ups for a vehicle to, say, CSV format for further data review using offline tools. I have searched and not really found anything. Help?
Thanks
Ken
2013 Nissan Xterra
Old 09-17-2022, 05:51 PM   #2 (permalink)
https://www.freecodecamp.org › news › what-is-a-csv-file-and-how-to-open-the-csv-file-format
What is a CSV File and How to Open the CSV File Format - freeCodeCamp.org
CSV stands for Comma Separated Values. A CSV file is a plain text file that stores tables and spreadsheet information. The contents are often a table of text, numbers, or dates. CSV files can be easily imported and exported using programs that store data in tables. CSV File Format. Usually the first line in a CSV file contains the table column ...
Sounds like a subset of tab-delimited text file.
'export all fill-ups for a vehicle to...' will depend on the source. What do you have? Some payment method may provide reports that can be scraped. In my case, using cash, printed reciepts that could be entered directly into a[n offline] tool wold be the only option.
Old 09-17-2022, 06:28 PM   #3 (permalink)
OK .... where do I access 'export all fill-ups for a vehicle to ...'? I can't find that on this site. To be clear, I want to export all fill-ups logged ON Ecomodder to a CSV file that can be saved on my computer.
Old 09-17-2022, 06:54 PM   #4 (permalink)
I was quoting you, but now I understand.
I suggest repeat the question in ecomodder.com/forum/forum-news-feedback. Linked for your convenience.
campisi (09-18-2022)
Old 09-18-2022, 08:24 AM   #5 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Probably not. However, you might be able to view them all, select the web page text and insert into a spreadsheet. You'll likely need to play with the formatting.
The Following User Says Thank You to ksa8907 For This Useful Post:
Old 09-18-2022, 08:28 AM   #6 (permalink)
Just tried it and it does work, be sure to insert to the correct sized table of cells.
Old 09-18-2022, 11:09 AM   #7 (permalink)
Thanks for that tip! I hadn't tried that. However, from your suggestion to just copy/paste from here to Excel I noticed a line at the very bottom of the fill-up log that I had not seen before:
View: spreadsheet friendly fuel log output (for copy/paste)
Perfect, as that view is ideal for the copy/paste you suggested. Works for me. Thanks!
export fuel log
