Old 05-02-2012, 10:28 AM   #1 (permalink)
Open Revolt 500A?
Hi, guys.
Someone told me that the Open Revolt controller (Cougar) is rated at 500A peak. The wiki page, however, states: "EV Series 500 & 1000 DC Motor Controller "Cougar" Features - Continuous current rating of 500 or 1000 Amps.
Is this person wrong? Or is there an error on the wiki page?
Thanks!
Old 05-02-2012, 10:38 AM   #2 (permalink)
There is a 500A controller and also a 1000A controller. I'm not sure if the 1000A is fully designed and tested yet though.
The Following User Says Thank You to Daox For This Useful Post:
Ryland (05-02-2012)
Old 05-02-2012, 11:25 AM   #3 (permalink)
But what I really want to know is if the 500A Cougar controller is rated for 500A continuous, or 500A max (peak).
Old 05-02-2012, 11:51 AM   #4 (permalink)
From the wiki (Open ReVolt - EcoModder)
Any voltage input in the range of 0 to 144v.
15.6 kHz switching frequency.
Adjustable hardware overcurrent shutdown.
Hardware over-current shuts down in 3-4 µs. [1]
RS-232 interface.
Reprogrammable.
High pedal lockout.
The controller will not close the main contactor if the mosfets have failed shorted.
Protection from many potentially destructive errors: [2]
Control board power polarity reversed
12V supply connected to throttle
Full throttle at 0 RPM
Old 05-02-2012, 12:17 PM   #5 (permalink)
PaulH
MPaulHolmes's Avatar
I think whoever wrote that did a booboo. It can do 500 amps for I don't know how long, but not continuous.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
Daox (05-02-2012)
Old 05-02-2012, 02:51 PM   #6 (permalink)
The motor that I'm considering is rated at 450A max (for 5 minutes)... 190A continuous. To me, the Open Revolt controller should work out well. Would you agree with this reasoning?
Old 05-02-2012, 04:06 PM   #7 (permalink)
PaulH
Ya, that would be good. I think Joe down in Phoenix uses around 180 amps continuous in 45 degC weather without any heating issues. I don't know what the continuous amp rating is, but I believe it's higher than 180.
kits and boards
Old 05-02-2012, 05:34 PM   #8 (permalink)
Great! Thanks for the info.
