Comparison of two GM affiliate models
Rear Side View: http://www.robietherobot.com/storm/i...rmbase9091.jpg Drag coefficient: .31 Frontal Area: ?? Then, the Saturn SC1 Front Side View: http://upload.wikimedia.org/wikipedi...Saturn_SC_.jpg Rear Side View: http://i394.photobucket.com/albums/p...s/P4040030.jpg Drag Coefficient: .318 Frontal Area: 2.06 Square Meters Finally, the GM EV1! Front Side View: http://www.altfuels.org/misc/graphics/ev1.jpg Rear Side View: http://www.getmsm.com/ev/EV1/2003_0726_115526AA.JPG Drag Coefficient: .19 Frontal Area: 1.89 Square Meters. Looks like for awhile, anyway, they were starting to "get it"... eh? |
Ah the SC1. My cousins GF had one.
It was great when the alternator mounting tab that was cast into the ENGINE BLOCK broke. That car was never fabulous at anything, but it sure ran for over 200k of an mindless neglectful female teenage driver. I was quite impressed with the shape of 2 cars I saw today. The Gen IV Mistu Eclipse and the Pontiac G6 Coupe. Both seemed to be very much 'boattailed' |
Christ -
Yeah, the Storm and SC1 were always eerily similar, and were part of the faux-wraparound rear window treatment that you'd also see in Oldsmobiles. I like to think of the late 80's and early 90's as the "aero era", if for no other reason, a lot of cars had below-headlight grills. I always thought the Geo Storm was really small, but I guess it was in my mind : Code:
Saturn SC1 CarloSW2 |
Storm/Impact 80-mpg car
The Storm served as a test-mule for the Impact electronics and powertrain. A couple years later,Ultralite,different looking,but identical Cd debuted with 100-mpg. The longer Saturn had one of the lowest Road Load Horsepower ratings of any car tested by Car and Driver. |
Could I throw another GM product into the mix
http://www.valmet-automotive.com/aut...libra_w500.jpg Opel Calibra 1989-1997 - cd of 0.26 in 8v form (the 16v, turbo and V6s were worse). Prior to this the Kadett E (aka Vauxhall Astra, Pontiac Le Mans, Daewoo all sorts) was also designed with aero in mind, including mostly having flat wheel covers skinny (i.e. Michelin X) tyres. http://www.pistonheads.com/pics/news/18726/tn29-L.jpg I remember reading a motoring journo long term review in the 80s and he praised the 1.3 litre Astra for being able to cruise at 100+ with 3 passangers. The 16v 160hp version was claimed to be capable of 150mph - although in reality it struggled to that. This was in 1985. And prior to this (we are in the 70s now) the Mk1 Vauxhall Cavalier was also aero styled for the time - flat wheel covers, sloped lights and so on. And this came after the Vauxhall "droop snoot" phase. http://www.droopsnoot.co.uk/Photos/Gallery044.jpg Droop snoot goodness here : Vauxhall Magnum - Wikipedia, the free encyclopedia |
I'd love to see reference made to the Storm in any type of Eco-car. I'm still not sure what engine I'll install in mine, I do believe that #1 rod is broken or the bearing is toast. Knocking sound when cranking, engine won't start. THere are lots of blocks that fit, but they all require extraneous work to run. I may just use the OE 1.6 for now, if I can find one. Of course, I'm also going to be looking into what kinds of aero improvements I can make, taking major cues from the EV1. Arragonis - Sure, and if you come across any more, feel free to let them join the party! I'm interested specifically in cars that had obvious aero advantages for this thread, and especially anything with a small, efficient engine/drivetrain. |
I am thanked by christ, I am blessed. I am off to bed.
aerohead -
I just found this picture in your "Other vehicles 1" gallery : http://ecomodder.com/forum/member-ae...oncept-car.jpg The nose of this car always reminded me of the Storm and the SC. CarloSW2 |
Lower the Lumina APV and cut the ridiculous bumper on it, and you've got that image up there. (Nevermind the back.)
Arragonis - Christ giveth, and Christ can taketh away! :P (Smart ass.) |
reference
Within the article,he discussed how the GM Sunraycer would make a 400-mpg car,and after qualifying a powertrain,made the mpg association to the Impact/EV-1. He never specifically mentions the Saturn or Storm,however,since the Storm did serve as a test mule,and it originally possessed the kind of powertrain he specified,I just made a mental leap,presuming an Impact-bodied Storm could achieve 100-mpg.I believe that is exactly the spirit of his comment. |
Photochop request!!!
Anyone with some skills, make the rear deck of the Geo look more like the rear deck of the EV1. See how the EV1 slopes down? The Storm is flat!!! I'm thinking about how I can make a "spoiler" to attach to the deck lid that will slope from the window down, but remain flush or even hang over just a smidgen of the trailing edge of the rear deck. |
Christ -
I couldn't find a good side view of the EV1, so here is an "ok" attempt : http://ecomodder.com/forum/member-cf...m-ev1-butt.jpg CarloSW2 |
Carlos -
You see the spoiler in the image of the Storm? If you remove that, the deck lid is basically flat. If you notice on the EV1, the decklid is sloped, although not as deeply as the rear window, to continue the reduction of the trailing wake. It's kind of like a Kamm shape, I suppose. What I'm proposing is the use of a ************ to make a wraparound "spoiler" that leads from about 1/3 of the way up the rear window to just past the edge of the deck lid, following that angle. **************** = Whatever it comes down to being. Your chop of the EV1 tail is revealing, though. By comparing the C-pillars, we find that the EV1 is slightly longer than the Storm, and the deck line lower, while the window conclusion is in nearly the same place relative to the ground line. That, of course, means that without serious body work, the Storm won't have the same body treatment, but I can get the basic taper easily enough, though I'll lose part of the rear window visibility. |
