Old 02-25-2009, 08:03 AM   #1 (permalink)
95 Saturn Strange VSS Readings past 50 mph
On my 95 Saturn SW2 I seem to get accurate VSS readings up to 50 mph. As I continue to accelerate past 50 the speed on the MPGuino decreases until I reach 59 mpg (on the speedometer) at which point the MPGuino reads 0. So basically once I hit 50 it starts counting backwards until it hits 0 when I am really going 59.
My VSS Pulses is set to 10000.
Can this be caused by too much wire length between my ECM and my MPGuino?
Thanks.
Old 02-25-2009, 09:58 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
FWIW, I've not heard of this problem in a saturn before.
You could try setting "VSS Delay ms" to 1 and see if that helps.
Old 02-25-2009, 06:29 PM   #3 (permalink)
Yes. That worked. Thanks.
I took the plunge! My Saturn conversion Heynow999 Fossil Fuel Free 13 02-28-2011 02:32 AM
95 Saturn SW2 VSS Problem junker OpenGauge / MPGuino FE computer 4 02-19-2009 12:37 PM
95 Saturn SW2 - Help identifying connections junker OpenGauge / MPGuino FE computer 2 02-08-2009 04:59 PM
Restricted fuel system affect mpguino readings? wagonman76 OpenGauge / MPGuino FE computer 1 09-09-2008 01:34 PM
Saturn LS (not SL) New Member sporkinum Success Stories 1 08-28-2008 05:26 PM
