EcoModder.com
-   -   Constant load cruise mod (https://ecomodder.com/forum/showthread.php/constant-load-cruise-mod-16863.html)
PLTWstudent 04-15-2011 01:49 PM
I am currently a student in an Engineering Design and Devolpment, Project Lead the Way class. As my final project, I have decided to improve cruise control by adding a mode where engine load instead of speed would be the constant. This mod woul be somehtinbg that piggybacks on the stock GM cruise. I would be testing this system on my personal car, a 1996 Pontiac Sunfire 2.2 liter 5 speed with factory cruise. I need to have a survey to prove my idea is good and going in exactly the right direction. Thank you for your responses.
PLTW GM Cruise Control Mod Survey
kstruve 04-15-2011 02:40 PM
Member jomelmaldonado has done that mod and posted his results on this forum.
http://ecomodder.com/forum/showthrea...ogic-2031.html
He starts posting on page three.
spirilis 04-15-2011 02:46 PM
That's pretty cool. Has anyone done any work on retrofitting a homebrew cruise control into a Drive-By-Wire throttle system? Is it possible?
(my wife's 2005 Ford Crown Vic is DBW and has no cruise control... it was a Police Interceptor model)
PLTWstudent 04-16-2011 03:22 PM
Interesting, but that doesn't work on a factory cruise module where nothing is adjustable.
Probably possible if you are some sort of programing god.
PLTWstudent 04-18-2011 02:42 PM
Thought: Use a universal cruise kit to operate the throttle pedal directly.
