Consumer Reports tests speed vs MPG & comes to false conclusion about Honda Insight 2
When I saw that Consumer Reports had recently done a comparison of the fuel consumption of various cars over a range of speeds (55, 65 & 75 mph), my first thought was: "good, more data to add to the pile."
Here's their data: http://forkenswift.com/album/7-cr-orig-mpg.gif All well and good, right? You could make some strong, logical conclusions from those figures. Right? Apparently not if you're Consumer Reports! Here's what they concluded and decided to highlight about the 2nd gen Honda Insight: Quote:
If we accept that fuel economy is the relationship between fuel used and distance travelled, then the Insight's absolute increase in fuel consumption caused by increasing speed actually lies closer to the middle of the pack of the vehicles tested. You can see this if you use litres/100 km (or you could use gallons/100 miles): http://forkenswift.com/album/7-cr-mpg-lpck-change.gif So the Insight may have had the biggest numerical MPG drop of the vehicles tested, but that's not the same as the largest change in fuel economy of the fleet. It's pretty clear that in terms of energy consumption, emissions, and money, the absolute costs of increasing speed (ie. most meaninful in the real world) are largest in the vehicles we would expect (the bigger ones with the largest engines). This is a glaring example of how MPG can be a misleading/confusing metric for consideration of fuel economy: I can only assume the writer saw the Insight's apparently "massive" 15 mpg drop and it drew her focus. |
It is very interesting how information can sometimes be presented, which is factual, but not necessarily correct in the respect of the right question, rather than a question. The data they presented is technically correct, but the way in which it is presented does make it appear that the insight is a "worse" performing vehicle and the way it is presented implies that it will give the user the worst value in mpg, which is completely not true.
Very interesting example of totally correct, misinformation. |
I would have said her statement was correct if she'd said the Insight experienced the "largest drop in MPG" rather than "fuel economy".
...they're all "...LIES, damn LIES, and STATISTICS..." , said Humorist Will Rogers.
...you'd figure they'd look at the "rates-of-change" or something, NOT the absolute numbers. |
Well, if you ask me the conclusion is not necessarily wrong. The Insight did have the biggest relative percentage drop in fuel economy. This just means that as speed increases its fuel economy goes down at a faster rate than other cars tested.
even at 75 mph the insight is still blowing the competition out of the water!!!
I don't like consumer reports anyway because they almost always vote for the ones that are crap.....
Consumer reports already decided to the new Insight is crap in a previous issue. Now they are just trying to reinforce that point of view. You should email them on this.
We could quibble about who had the biggest percentage drop, depending on how you compute it, blah blah blah.
But I did notice that the Insight still returned the best fuel economy of the vehicles in the test cohort, even at 75 mph. I would also note that I'm pretty sure I could beat the Insight with my 04 VW diesel at 75 mph, and maybe the other speeds as well. Admittedly, that's using hypermiling techniques, while they are following some "normal" protocol. Finest regards, troy |
But I still feel that absolute (vs. relative) fuel economy figures are more meaningful/useful to the average person in a comparison like this. The writer has decided that the slope of the graph is more significant than the actual fuel used in the change from 55 to 75: Quote:
--- tjts1: they have comments under this Consumer Reports piece. Since I posted this, someone has brought up the same topic. (Not me!) Commenter says: Quote:
You should go fix her wagon.
