EcoModder.com
-   Fossil Fuel Free (https://ecomodder.com/forum/fossil-fuel-free.html)
-   -   converting old EV into power generator (https://ecomodder.com/forum/showthread.php/converting-old-ev-into-power-generator-40140.html)
Tahoe_Hybrid 04-09-2022 03:46 AM
has anyone converted an old expendable EV into a power generator? i.e wind turbine or water turbine generator?
Piotrsko 04-09-2022 09:42 AM
You could but you need a big structural tower and fairly long blades to get any useful power out of the inefficient motor turned generator. Probably cant get permits in most residential jurisdictions
freebeard 04-09-2022 12:13 PM
I have as an example, a Lexus electric axle. It's 68 HP rating is 50 kW. Assume [arguable] parity for generation.
Originally Posted by DDG
Aeolos Aeolos-H 50kW - 50,00 kW - Wind turbine
https://en.wind-turbine-models.com › turbines › 1856-aeolos-aeolos-h-50kw
The rotor area amounts to 254,5 m˛.
254,5 m˛ is 18 meters diameter. Or 19.8 yards. Or 59 feet.
I think the best way would be to weld the spider gears and put it on top of a gravity vortex water mill, where it's up above the water. That would require a sizable creek and impoundment dam.
Should be biking 05-15-2022 07:47 PM
There’s a huge Wind farm near Palm Springs, CA where you can take a tour to see the wind turbines up close. They are enormous if you’ve never been up close to one. At the entrance they have an exhibit of wind turbine designs through the years and how the first few iterations just did not last. The designs that seemed to hold up were at least twice as beefy as the first designs and they all integrated a brake to avoid overspeeding. One of the failed designs had a phrase that stuck out to me that was something like “Proving once again that designing a wind turbine is no easy task”.
Tahoe_Hybrid 05-15-2022 10:20 PM
well it can spin 120mph those wind turbines can barely do 35mph, not that fast
Should be biking 05-16-2022 10:34 PM
The gearing is going to be different. I think at best youÂ’ll be disappointed by the power output considering how much work is required to build this from EV parts. Which is what Piotrsko already said.
freebeard 05-17-2022 12:13 AM
GM eAssist have a 15hp altermotor on a serpentine belt.
cRiPpLe_rOoStEr 05-17-2022 05:38 PM
Not exactly what I would consider a full-EV motor, even though I guess it could get the job done for certain really-small cars and those Japanese old-school tiller tractors. On a sidenote, there were times when I considered trying to make a wind power generator resorting to a regular alternator, even though it would be limited to 12-volt mostly for auxiliary power. Might eventually give it a try someday, even though it's not so likely to happen while I live in an apartment :turtle:
freebeard 05-17-2022 06:31 PM
It is an OEM component. Isn't that enough?
The discussion had trended to how big an installation would be needed for a 68hp axle. The swept area for the altermotor wold be much more manageable, plus the opportunity for gearing options.
oil pan 4 05-17-2022 06:45 PM
Better off with solar panels.
