coroplast cold frame
I just built something Ive been dreaming of building for a long time. from a single 4x8 sheet of uv coroplast I made two 4 foot long mini row cold frames. I'll post up a pic in a day or so. I still need to work out a vent for each end.
http://a5.sphotos.ak.fbcdn.net/hphot...63427422_n.jpg I will also post a pic of a clay form for making newspaper seedling pots. I formed over 75 seedling pots but my wife took 25 of them to plant sunflowers with her grade 1 science class !http://a6.sphotos.ak.fbcdn.net/hphot...43129469_n.jpg that left me with 53 pots. I planted 3 types of pumpkins, three types of tomato, romanesco, purple cauliflower, pickling cucumbers, swiss chard, giant sunflowers and teddy bear sunflowers . I have some lettuce mix for the mini green house, and some spinich to plant in an uncovered bed. HTTP://a4.sphotos.ak.fbcdn.net/hphot...08279725_n.jpg |
also planted watermelons and muskmelons
I wish I had built automatic lifters for the lites when I built my coldframe.
A quonset ganzfeld for plants....
When you made the paper pots, do you use any adhesive on the paper? Just water? |
no adhesive,i actually use a tabbing system. i roll the paper about 5 times to make a rim. then i wind the rim at the top of the mold. i spin the paper to fold it down into the tapered shape then press the excess paper into a small divot at the bottom. after i remove the mold i rip the rim near the end piece so that i can unroll a one inch section and i tuck it insde the pot. the soil holds the tab against the inside wall of the pot.
i just made twenty more today because i forgot to plant peppers. this time i rolled some peatmoss into the rim and into he pot wall before i sealed it up. My last set of pots started to mold and i am afraid the seedling might be damping off. |
http://www.fourmilab.ch/images/Roman...mages/Scr5.jpg |
