Crapped. 2 tires have bubbles.
Was taking pictures of my car today and found out that the 2 rear tires have bubble on the sides/edge of the tires.
Tires are: Toyo 800 Ultra Premium. Tires were purchased in 1998 with 45K on the odometer. Now it's 84K and the tires still have alot of treads left on them. Guess I'll just buy 2 replacement and put those on the fronts and the other 2 Toyo in the rears. Any specific tires to get? Current size is 175/70/13. Or should I just replace all 4 tires with stock size and keep the other 2 as spares? |
Personally, I wouldn't trust a tire over 5 or 6 years old. They wear quicker and are more prone to blowouts at the older age.
Yes get replacement ones. My father does MOT tests (British government road worthiness test) for a living and having bubbles or bulges on the tires would be cause to fail the car, as i learned when he found some while checking over my car a while back. Something about how the bubble is equivalent to a hernia would be on a person, to paraphrase him.
Basically if it looks dodgy get a new tires since you don't want to mess around not getting something as important as them. |
I don't know if you should replace them or not, but if you get two new ones, they go on the rear and the old ones should go up front.
Well I need to find a new set asap because tomorrow is the start of "No-Tax" weekend.
:thumbup: |
Nope, I just found this out when my friend had to get two new tires, the shop put them on the rear.
It turns out that it is much easier to regain control if your front end slides out than if the rear end does. Also, in a panic situation, most people's instinct is to brake, which puts more weight and thus more traction on the front tires. So the new tires always go on the rear. |
No shops around have any 165/70/13 in stock! They are all special order one. Sears quoted me 175/70/13 Sumitomo HTR for $350, includes installation. While I can get the 165/70/13 from tirerack for $41 each. $200 shipped.
Or should I up the size to 175/70/13 and stick with those? There are more options and cheaper prices. |
