Old 07-17-2008, 02:55 PM   #1 (permalink)
Wildfire - '96 Ford Bronco XL
90 day: 14.88 mpg (US)
Blackford - '96 Ford Bronco XLT
90 day: 20.26 mpg (US)
Y2k - '00 Honda Insight
Gen-1 Insights
90 day: 73.98 mpg (US)
Redford V10 - '01 Ford F250 Lariat
90 day: 15.64 mpg (US)
FireFly - '00 Honda Insight DX
90 day: 69.43 mpg (US)
LittleRed - '00 Honda Insight
Lightbulb TBI Switch?
I'm sure this has been discussed a billion times before....
I'm thinking of installing a TBI cutout switch. The idea is to have an enable/disable switch near the stick shift or e-brake so that "disabled" the car runs normal - engine on all the time. "Enabled" will allow a TBI wire to be interrupted whenever I push in the clutch - where I will have a second momentary switch near the already installed start contact. This would cut fuel to the engine with the clutch engaged, then when I start allowing the clutch pedal to move out, the TBI circuit would make and run the engine again. This would give me an Engine Off Pulse and Glide with minimal "operator interface". I would wire these two switches and use a relay as needed to make this happen.
If I have to stop, I can place the switch to "disable", and then I can go through the gears normally until it is time to do Engine Off Pulse and Glide.
This could double as a kill switch/theft deterrent.
Any thoughts, or am I high as a kite?
Thanks in advance.
99 Chevy Metro 3 cyl/5 spd manual
Old 07-17-2008, 03:27 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
It is better to interrupt the ignition in my experience. The TBI (and even MPFI to some extent) leaves fuel in the manifold that makes the car stumble on.
Old 07-28-2008, 08:56 PM   #3 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Geo Metro Xfi
90 day: 51.06 mpg (US)
I wrote a how-to on this exact thing. I shut off my Injector for the reason that dcb mentioned I do not want extra fuel laying there unburnt and going into oil, etc. So I decided to leave ignition on to burn that fuel. Here is the how-to. TeamSwift • View topic - EOC (engine off coasting) Switch how-to XFI
Old 07-28-2008, 11:01 PM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
FYI, this info is now buried, but you may have to make an adjustment to the mpguino circuit if your kill switch is interrupting the injectors and not the ignition.
Old 07-28-2008, 11:44 PM   #5 (permalink)
Addicted
bbjsw10's Avatar
Sorry to raise it from dead, just noticed what they where looking for was what I made. On the mpguino I think I will make it so the lead to guino is shut off when EOC switch is on. Will just have to test it out I guess. Thanks for mentioning this though had not thought about it.
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 40 06-18-2012 03:13 AM
Hypermiling issues: Worn out ignition switch larrydag Hypermiling / EcoDriver's Ed 18 03-05-2011 04:38 PM
Normally closed momentary switch. getnpsi DIY / How-to 21 08-29-2009 11:29 AM
DRL Kill Switch? gamer_jim EcoModding Central 8 06-05-2008 10:12 AM
Winter mod - heater blower integrated with engine kill switch MetroMPG EcoModding Central 3 12-31-2007 10:31 PM
