EcoModder.com
-   Success Stories (https://ecomodder.com/forum/success-stories.html)
-   -   Cruising at 60+ mpg @ 60 mph (https://ecomodder.com/forum/showthread.php/cruising-60-mpg-60-mph-26376.html)
California98Civic 07-11-2013 09:39 AM
In this warm weather, I cruised 250 miles Tuesday and Wednesday on the freeways here and averaged 64.xx mpg. My speeds varied from 55-60mph. With a few more good aeromods, maybe my long sought goal of 60/60 cruising (60 mph and 60 mpg) is almost in reach.
user removed 07-11-2013 10:22 AM
At a steady 60 MPH my Fiesta will push just past 50 MPH.
regards
Mech
MetroMPG 07-11-2013 11:57 AM
MPG MPH MP?
Congrats! 60 at 60 is Gen 2 Prius territory.
I have a saying for my Firefly: "70 at 70". But that's MPG (US) at km/h. :D
PaleMelanesian 07-11-2013 12:37 PM
My stock Fit is 50 @ 50, so your result is impressive.
PressEnter[] 07-11-2013 01:32 PM
Very nice!
60@60 is about what the TDI manages. Having a 6th gear helps :p
cbaber 07-11-2013 01:57 PM
What RPM are you at going 60 mph? Do you contribute your success to the aeromods or the long VX gearing, or a mixture of everything?
I've got to repair my HX transmission and I have been thinking about just swapping it for a VX instead of repairing. Right now I am at 2250 RPM at 60 mph. I have slightly taller tires than stock.
California98Civic 07-11-2013 03:04 PM
I'm around 1950rpms at 60mph. The '93 CX transmission is without doubt a big factor, but I follow the idea of getting a bunch of small benefits from multiple mods--weight, engine, and aero--together and "stack" them up until it equals a big difference. The biggest benefits seemed to come from deleting the power steering and the alternator. Deleting 200+ pounds in weight from the car. Pumped up tires. And the airdam and grill blocking. I think the WAI helps too--or at least my testing suggested it did.
I did very little hypermiling, by my standards, on this trip. So the engine kill switch was less significant than usually. I held steady throttle as much as traffic or hills permitted. At some stretched the instant MPG reading would cross 70. At others it would be under 60. I did some mild drafting, one or twice cut the engine, coasted in neutral down the rare large hills or when traffic piled up in front of me.
Warm weather helps a lot. I won't get this number in the winter.
Need more aeromods!
basjoos 07-11-2013 03:15 PM
70@70 below 1000 ft elevation and 75@75 above 2000 ft elevation in the aerocivic. The mileage improves with altitude.
MetroMPG 07-11-2013 03:18 PM
Which is why I like your car/projects. Multidisciplinary! Added this thread to the front page.
California98Civic 07-12-2013 08:30 PM
Way cool. Thanks. It's a fun ride these days, but I want that last measure of economy. Want to get to 60/60.
