EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   CRX Mugen Wing? (https://ecomodder.com/forum/showthread.php/crx-mugen-wing-2942.html)
88CRX 06-10-2008 04:59 AM
CRX Mugen Wing?
I think this is a mugen style wing:
http://members.lycos.nl/yourcrxgalle...crx/fmegna.jpg
Do you guys think it will decrease Cd?
tasdrouille 06-10-2008 07:42 AM
I might help. Worst case it'll change nothing.
Shawn D. 06-10-2008 08:15 AM
I think it'll make it worse due to the wraparound sections on the sides.
MetroMPG 06-10-2008 08:36 AM
It won't do much with that sunroof open! :p
The side portion shouldn't hurt, provided it follows the existing body taper (or is slightly more tapered). Hard to tell from the pic, but it looks like it at least follows the existing lines.
SVOboy 06-10-2008 11:55 AM
The mugen wing does follow the existing lines...I've always wanted one.
ebacherville 06-10-2008 12:04 PM
it will extend the tail out a bit making a very slight angle decrease to the hatch .. doubt you'll see a big difference but looks basically like a kammback mod.. on a tamer scale.. couldn't hurt
2003protege 06-10-2008 02:26 PM
IF the wraparound sections follow the body lines, I would say it could only help by a negligible margin.
IF the horizontal piece follows the body line, its kammback properties might be negated by the increased wetted flow area. Remember, the purpose of a kammback is to reduce the amount of drag by to eliminating surface area.
IF you want it 'cause it looks cool, GO FOR IT, 'cause it's not hurtin anything significantly
IF you're justifying the purchase by saying it'll save you gas, it will probably take like four years to pay for itself if it even helps at all
=P
IMO it looks pretty cool.
88CRX 06-11-2008 12:07 AM
Thanks for the input. If i find a used one I'll try to get it.... they seem really rare.
aerohead 06-12-2008 05:35 PM
Mugen Wing
My thought is that since it's Mugen,it was built for "performance".Since it has no up-sweep it should not induce drag and my guess is that they're using it to move the low pressure wake underneath it to create a little downforce,without the drag penalty.Since it increases the fineness-ratio a tad that's also not bad.It's a perfect fit,it doesn't block your vision,could show a smidge better on fuel,I'll vote,keep it!
88CRX 06-12-2008 09:48 PM
Thanks, but i haven't got it... only thinking of getting it, only if i get a good deal :)
