Old 06-22-2016, 10:59 AM   #1 (permalink)
The Black Clio - '04 Renault Clio
Manual Operating front grill opening & blocking
Hey everyone.
Ive heard a few people say they have blocked off their front grill but then they have added a sliding opening so when the temperature starts to rise they can then open it fron within the car.
Im looking to do the same thing as my car is getting a bit hot sometimes. Im wondering how some of you's have set up the sliding mechanism, do you just pull a piece of string or is it set up using a wire system like the bonnet mechanism? I could easily make the sliding door but i want to be able to open and close it from inside the car manually.
Im not looking for any electrical methods as im trying to keeo costs down.
Thanks
Mark
Old 06-26-2016, 07:28 AM   #2 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Yup, that's what a few people have done. A bicycle brake or shift cable is an easy and fairly fool proof way to go.
In fact you can use an old bike shift lever in the cabin, and you're half way there.
Old 06-26-2016, 03:59 PM   #3 (permalink)
The donkey CRX's Avatar
MULE VX - '92 Honda civic VX
90 day: 92.6 mpg (US)
White 94 VX "Show Car" - '94 Honda Civic VX VX
90 day: 79.92 mpg (US)
The Walrus - '02 Honda Insight base
Gen-1 Insights
90 day: 100.88 mpg (US)
Reply to Marky
I would second Old Telly with the advice to make sure you have a reliable way to monitor your water temp before blocking your grill.
Here is a picture of the cheapest "push-pull" cable I have found. It is from JEGS racing products and was about $9 US when I bought it last year. It only has a 2" "throw" so you will need to make a lever to allow more than 2 inches of movement. Also being low cost, when the cable moves in and out, it also twists, which can cause binding.
If you what to spend more money, JEGS also has heavy duty push pull cables with a 3" "throw" for around $50 US. Here is an example of the better quality cable being used to operate a manually adjustable grill block.
Here is a picture of how the cable is mounted in the car.
Hope this gives you some ideas fro your project.
