Custom bike sprockets
I'm about to assemble the electric motorcycle I have and about to mount the motor. Next step is the sprockets. I'm going with a 5:1 ratio, so I need a 70 tooth rear sprocket. I'm having a hard time finding vendors who offer 70 teeth for a 1996 Honda CBR 600 F3. Does anyone know of any vendors who make 70 tooth sprockets for motorcycles? What prices should I be looking at?
IIRC stock for a CBR F3 is 14/43. I know you can get a 13T front and 46T rear in the aftermarket but I don't think you will get a 70 tooth even going custom.
Your best bet would be to try to find a place that sells stunt bike parts. Typically that niche market isn't concerned about speed but power to do their tricks...Which is promising for what you need. |
specific tooling investment divided on very small batches of parts = high selling price, that is just fair.
It's either 125$ sprocket (and chain to the meter obviously) or you could engineer a twin reduction setup based on standard sprockets. Standard front sprockets drive standard rear sprocket that drives standart front sprocket that drives standard rear sprocket. All in all, you end up with a setup that might be more expensive to start with (but a fair bit less on the long run). I'd go for the 125$ custom sprocket ... |
electricmotorsport.com makes custom sprockets. if I remember correctly they are about $100.
Rebel Gears in Crossville TN will make sprockets up to 96t. REBEL GEARS CUSTOM MADE MOTORCYCLE SPROCKETS ANY SIZE
if you know the donor bike, visit The UK, there is a pic of bolting pattern for each sprocket
Also, I would really appreciate a link to the build diary of your EV conversion !
I'm going to get pictures tonight because right now it's stripped to the frame. I'm basically at step 1. I'm assembling the motor brackets this week and I'll get pictures of that as well. Once the brackets are on I'm going to paint the bike. I'll definitely get step by step pictures and once it's all done I'll compile a guide with everything I've done. It should be very helpful for other DIY folks. |
You can just call or e-mail Rebel Gears with the rear wheel you are using and they can make it to fit. I have done this several times changing numbers of teeth and chain size. Usually get it within a few days, and very reasonably priced. I have no affiliation with them:) just great people to deal with.
But that link provided by renault_megane_dci was a great help. |
