EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   custom mirror (https://ecomodder.com/forum/showthread.php/custom-mirror-4160.html)
fredd7924 07-29-2008 07:43 PM
custom mirror
I like having a mirror on the drivers side, so I am making a custom mirror on the drivers side. I already made a block off plate on the passenger side using sheet metal.
http://a732.ac-images.myspacecdn.com...5e6d50949b.jpg
The drivers side will be the same basic block off plate but with a mirror and a cone design on top. I just have a piece of paper as a template for now. It sticks out about as far as the stock mirror folded in. The final version will have sheet metal instead. I just need to figure out a way to hold the mirror on and keep it semi adjustable.
http://a619.ac-images.myspacecdn.com...fa9747ee7a.jpg
http://a747.ac-images.myspacecdn.com...a4c506ec22.jpg
what do you guys think?
cfg83 07-29-2008 09:11 PM
fredd7924 -
I really like where you're going. The conical shape reminds me of the ones I see on Euro-Sport Golfs. I can't find a picture of it, but I think you know what I mean.
CarloSW2
Bicycle Bob 07-29-2008 09:41 PM
The shape looks like it would create a larger wake than one with curves to give flow parallel to the main flow at the back edge.
SVOboy 07-29-2008 09:45 PM
^ Agreed. My rudimentary understanding of aerodynamics would say that you should make it into a teardrop as much as possible.
MetroMPG 07-31-2008 10:05 PM
A hemispherical shape at the forward part of the mirror would be better than a cone shape. But I bet that even with the cone, the decrease in frontal area & Cd compared to the stock mirror will be worth it even if it's not the perfect shape.
cfg83 08-01-2008 06:04 AM
SVOboy -
Like this?
Originally Posted by cfg83 (Post 43275)
CarloSW2
justpassntime 08-01-2008 06:14 AM
I think it might work better on the car, not much reason to have it on the house. But it looks like a really good idea, smaller is better for aero. I want to do something like this on my car but I want to retain the electric adjustability of it.
Keep going I want to see the finished product.
fredd7924 08-01-2008 09:24 AM
i know that my design is not perfect, but i also would like it to be somewhat aesthetically appealing because i am young and looks still matter. I like the idea of the egg mirror, but think it looks a little silly. I am still trying to figure out a way to mount the mirror inside the housing without it vibrating around. I might just make it none adjustable.
cfg83 08-01-2008 02:34 PM
fredd7924 -
Yup, it does look silly, but I am old and my car is already beyond silly, :D . Also, the transparent part is still cloudy and there are reflections on the transparent part, so it's not ideal. I mostly use it for parking.
I wish I could find a picture of those smallish (Euro?-)racing mirrors that are very flush and conical in appearance, very similar to yours.
CarloSW2
fredd7924 08-06-2008 08:04 PM
i worked on it a little bit today but i don't think i like it, here are some pictures. everything is just resting together, pretty much just a mach up. if i keep it, ill smooth it up and paint it. tell me what you think.
http://a381.ac-images.myspacecdn.com...3c3d5c6a7c.jpg
http://a552.ac-images.myspacecdn.com...0ab1feb087.jpg
