Old 06-13-2008, 07:07 PM   #1 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
Lower idle RPMs save gas?
I think my CRV is doing about 800 RPMs at idle after warm up. (5 speed standard shift).
I was wondering if I could somehow adjust it a bit lower to save a little
gas while waiting at stop signs etc.?.
Or, will the car start stalling out if it runs too slow?
Thanks,
Rich
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 06-13-2008, 07:40 PM   #2 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Ford Thunderbird
90 day: 27.75 mpg (US)
The Civic VX idles at 400rpm to help conserve gas.
You might run into vibrational issues if you try lowering your idle speed, however. I'm not sure if the VX used any special technique (i.e. precise crankshaft balancing) to achieve such a low idle speed. Ideally, you'll want to kill the engine and remove the need to idle in the first place.
- LostCause
Old 06-13-2008, 10:46 PM   #3 (permalink)
I've been looking in this Haynes repair manual and it says the CRV idle should be set to
480 (+/- 50) RPM.
My Scanguage2 has been displaying around 800 after warm up.
I might try to lower it down to around 450 and see how it works..
I have started shutting the engine off at long stop lights, but when I pull up to a
stop sign and have to wait for a few cars to come over the hill and pass by,
I have no clue how long I'll be waiting, it can be 5 to 45 seconds.
So, since most of the time, it's only 15 or 20 seconds, I'm going to save some wear-n-tear and leave the engine idling.
And, when I'm in stop and go traffic, moving for 15 seconds and stopping for 15 seconds, logic says having a lower idle could save some fuel..
Cheers,
Rich
Old 06-13-2008, 11:07 PM   #4 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
lower idle does save fuel but vibration issues take over with the diesel.
i cut the engine way before i get to the stop sign and then bump start it when i'm just stopping in 4th. (direct)
Old 06-14-2008, 10:00 PM   #5 (permalink)
Impatient Driver
chrislk1986's Avatar
98CivicHX - '98 Honda Civic HX
90 day: 40.02 mpg (US)
If you're idling too low you might end up with lubrication issues, vibration is never good and you'd probably end up stalling it. 480 seems low for a crv or any honda for that fact. 600-800 seems normal for pretty much any honda engine.
Keep the idle speed where it's supposed to be, its there for a reason. Just turn the car off :P
But if you still want that super low idle, try the poor mans technique, which is lifting up on the accelerator.
Old 06-14-2008, 10:19 PM   #6 (permalink)
There's a table on this page.
http://autorepair.about.com/library/faqs/bl490g.htm
It says 750 +/- 50.. So, maybe my repair manual is wrong.
I'll just leave it like it is for now.
It just seemed like 800 was too fast.. I can actually release the clutch very slowly
and take off, without ever touching the gas.. Of course, I'm moving VERY slowly..
Cheers,
Rich
idle
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Disconnected Idle Air Control - for lower RPM after a cold start Lazarus EcoModding Central 19 04-15-2011 03:50 PM
Lower gas in tank = lower gas FE? NoCO2 Hypermiling / EcoDriver's Ed 10 06-09-2008 01:37 AM
new here, want to save gas! rocket Introductions 5 04-23-2008 02:06 PM
