EcoModder.com
-   Success Stories (https://ecomodder.com/forum/success-stories.html)
-   -   Dam, It works! (Air dam on Smart Fortwo: 3-4% MPG improvement) (https://ecomodder.com/forum/showthread.php/dam-works-air-dam-smart-fortwo-3-4-a-26046.html)
chumly 06-02-2013 06:32 PM
I just made an air dam out of some lawn edging. A B A testing shows 3.16%-4.2 % (avg 3.73%) better mileage. It took a whole half hour to make and install it, I should have done this a long time ago! :D Chumly
http://i.imgur.com/DLyhmKG.jpg
wmjinman 06-02-2013 06:48 PM
Good job! :thumbup:
MetroMPG 06-03-2013 09:52 PM
Thanks for posting!
What speed did you test at?
Do you have a picture showing the whole front of the car?
UltArc 06-03-2013 10:01 PM
I was anticipating test results and procedures...please?
chumly 06-04-2013 11:34 AM
I drove the car about 20 miles before any testing so it was completely warmed up. A is with the dam and B is without. I reset the scangage at a set point after getting up to speed and set the cruise control at 60 to be consistent, drove 5 miles one way, turned around in a parking lot and returned to set point on all three runs. Temps were the same on all three runs with a stop of maybe 5 min. between runs to take off dam and to reinstall it. On the last run I actually had to pass a car but I didn't need to touch the throttle, I don't think it should have made much difference. A=46.1 mpg, B=44.2 mpg and A=45.6 mpg. Chumly
knochenhauer 06-04-2013 11:54 AM
How did you mount the edging to your bumper? We would love to see more pictures of the installation!
MetroMPG 06-04-2013 12:14 PM
I'd like to put this on the front page, if you like. Please post another pic or two showing the whole front of the car.
chumly 06-04-2013 12:23 PM
http://i.imgur.com/JQ59min.jpg
MetroMPG 06-04-2013 12:32 PM
Thanks! The black pizza pans look good, too!
chumly 06-04-2013 12:39 PM
2 Attachment(s)
Attachment 13158
Attachment 13159 More pics
chumly 06-04-2013 12:44 PM
I just screwed it to the front valence with some panhead screws and put a thick wire through the tube in the edging to stiffen it up.
chumly 06-04-2013 12:47 PM
Sure , go ahead. I'm still computer illiterate (according to my wife and kids).
aktacoma 06-04-2013 03:54 PM
did you use lexan for the grill block? yours is much better looking than my white coroplast one on my red truck... havent gotten to painting it yet.
101Volts 06-04-2013 05:19 PM
Tis inspirational, I feel like sticking one on "Boxy" But what could I make it out of other than Coroplast?
aktacoma 06-04-2013 07:21 PM
the air dam? or the grill block?
for the air dam I believe most people use the lawn edging, right?
Shortie771 06-04-2013 08:46 PM
I have heard that for air dams some people use conveyor belt material, due to its durability.
aktacoma 06-04-2013 08:51 PM
Yes conveyor belt would work well the stuff isn't very light FYI and its not cheap to buy new.. But if you can find someone with used stuff that would work I haven't used it for this but I might seeing as I could get it for free from a friends construction out fit.
chumly 06-04-2013 11:48 PM
One day I was in my garage and noticed the old bug shield I found months ago and decided to try it because it looked like it would work if I trimmed it and it did.I think it's made of plexiglas but if was to buy the material I think I would use Lexan ,it's less brittle. I wanted to still use my foglights if necessary and so far no problems. Chumly
RiderofBikes 06-05-2013 10:11 AM
maybe 1/8" thick polycarbonate for your grill block? Flexible enough, pretty indestrucable and virtually scratch proof. That way you can get a pretty fluid fit and finish against the body as well.
elhigh 06-05-2013 01:01 PM
If you have any edging left over, make some rocker skirts for your fortwo.
Anything that can get the mileage up on those is a good thing. Seeing an EPA rating of just 38 blew my mind, I thought, "surely these little things can do better? On premium, no less?"
hawk2100n 06-05-2013 01:41 PM
I installed a lawn edging air dam a few weeks ago as well as partial rear underbody panels to reduce the drag from the rear bumper and I have seen gains of about 2+ mpg on the highway. The lawn edging is very resillient. I accidentally left my car in neutral and walked away, it rolled forward and absolutely smushed the air dam on the curb. Backed the car up and the air dam popped right back into place.
I've got some pictures on my build thread. Like OP said, this should have been done a year ago; it was that easy.
chumly 06-05-2013 01:54 PM
When I bought the car EPA said 33 city and 41 highway. My 1st tank was 43 mpg. I've already gotten over 78mpg on flat ground with no wind for a couple miles . The smart does much better at 50 vs 60 mph, it seems to lose about 1 mpg per every mph above 50. I'm willing to try anything as long as it doesn't cost too much. I live in a rural area so the traffic is usually light which helps a lot. Chumly
MetroMPG 06-05-2013 02:04 PM
Chumly, has anyone put a Kammback or boat tail on a Fortwo, that you know of?
elhigh 06-05-2013 04:28 PM
Whoops! My bad
Originally Posted by chumly (Post 374898)
When I bought the car EPA said 33 city and 41 highway. Chumly
I misremembered; the 38 is actually in reference to the Ford Fiesta I was writing about as an alternative to the fortwo in a blog post. Yes, 41.
Still requires premium, though.
ausias 06-05-2013 06:15 PM
the airdam is a very good invention. IT works very good in my car. But I'm using a 45º airdam.
chumly 06-05-2013 07:21 PM
Not that I know of but it shouldn't be too hard to do on the coupe but I have the cabrio, it's not that I didn't think about it. I already have some vg's on the spoiler, if nothing else they help in handling on the rare times I drive faster than normal. Chumly
Shortie771 06-05-2013 11:50 PM
I think that with how short a smart is, a boat tail could net you some great gains without sacrificing drivability and parking. The extra acceleration and higher top speed doesn't hurt either. :)
MetroMPG 06-06-2013 10:39 AM
:D
http://ecomodder.com/blog/wp-content...5/smartera.jpg
From: http://ecomodder.com/forum/showthrea...aybe-8293.html
(More "practical" examples of aero Smarts in that thread.)
101Volts 06-06-2013 01:17 PM
I was referring to the air dam. I'm seriously considering putting one on the ol' "Box", Though I don't have tank-to-tank date for the car yet.
mbarrus 06-10-2013 01:09 PM
I took inspiration from this thread and made an air dam for my Jeep over the weekend. I'm planning on making one for our Sentra once my wife returns back from a trip with the car.
Pics forthcoming.
chumly 11-22-2013 01:33 PM
I finally got around to making the side skirts out of a vinyl gutter, it took less than an hour to do (minus paint drying time), 1 vinyl gutter, 1 can of spray paint and 12 screws. I'm still testing and it looks very promising, more stable in wind and mileage seems to improve but the weather hasn't cooperated lately (colder). I'm still getting better mileage in cold weather than I did before installation:D but I'm not done testing. Chumly
CitroX 11-26-2013 08:04 AM
Good looking mods :thumbup: I tried an air dam - splitter. It did harm for my mpg. Maybe it was the splitter bit. However I have a full belly pan and a boat tail. So it might be that air underneath the car does not do that much damage but the increased frontal area does.
https://fbcdn-sphotos-d-a.akamaihd.n...10116470_n.jpg
euromodder 11-26-2013 08:40 AM
Don't drop the air dam lower than your belly pan.
Remove the splitter
It so pronounced (about 5cm , 2" ?) that it causes extra downforce = extra rolling resistance = extra drag
CitroX 11-26-2013 09:18 AM
It is long gone. I expected that the results would be negative on the mpg, but this ford rs splitter was lying around so had to try it :). The down force was somewhat noticeable and the car felt more stable though.
NeilBlanchard 11-26-2013 07:30 PM
Did you try a full upper grill block and a partial lower grill block?
CitroX 11-27-2013 06:29 AM
Yes. I've tried a number of combinations (cooling fan is operated by a switch by the way). This engine cools very well even without the fan so i do not need to use it, but blocking too much decreased the mpg dramatically, on some runs I even had as low as 34 (normally getting about 49). So by trial and error I ended up blocking about 50% of the bumper and hud grill. The gains seem to be under 2%.
geo1991 12-19-2013 01:05 PM
Great inventive use of materials.
ECONORAM 12-22-2013 08:47 PM
I am curious as to how you fastened your wheel covers on the wheels. Did you bolt them on, with washers holding the bolts in place?
I am not following the 45º air dam idea? Is it angled forwards at 45º to the road surface?
ECONORAM 12-22-2013 08:53 PM
Curious results. I have a home-brew splitter on my truck, and it honestly seems to help. (No formal A-B-A tests, but some back to back drives to work) It protrudes about the same amount (5cm), but is mounted directly under the factory plastic air dam. I did try to extend one down about 2 inches lower before, and that was detrimental. The splitter with a set of belly panels seems to do pretty good...
So I wonder now, if your belly panels had been level with the splitter how things would have tested....
CitroX 12-23-2013 03:30 AM
Look a few posts above which explain why the mpg dropped on my car ;). And if the belly would be as low as the splitter the car would be undriveable.
