Old 04-12-2013, 12:00 PM   #1 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Motor Racing to 3000RPM at idle!?!
My dad has a 93festiva L 5sp manual (used to be an auto but we swapped it ((might be relevant?))
Since we swapped in the motor all it does is race/smoke and there very is little braking power.
We switched out the egr valve, and some relays which didn't change anything.
Any suggestions as to what the issue might be? Maybe a computer issue? Intake manifold gasket seal bad? Any thoughts are appreciated. Thanks~
Old 04-12-2013, 12:14 PM   #2 (permalink)
riddleyo's Avatar
2002 VW Jetta TDI - '02 Volkswagen Jetta TDI
90 day: 44.28 mpg (US)
2000 Toyota Celica GTS - '00 Toyota Celica GTS
90 day: 35.64 mpg (US)
I am not familiar with festivas but a racing motor sounds like it just injesting too much air. Inspect the throttle body linkage, throttle plate sticking, throttle stop screw set incorrectly, or intake air control valve (if it has one) not functioning properly. The brakes are usually helped by the brake booster which uses vacuum assist. If the motor is racing, there is low vacuum which means the brakes don't work well.
The Following User Says Thank You to riddleyo For This Useful Post:
mikeyjd (04-12-2013)
Old 04-12-2013, 01:27 PM   #3 (permalink)
Vacuum leak. Not sure if the AT had a vacuum modulator but that would be my first suspect.
regards
Mech
