Desire to save money on gas makes cars explode
Desire to save money on gas may make cars explode | www.kirotv.com
yyyeeeeeaaaaaahhhhhhhh. :rolleyes: |
So the mpg is way better until 55 gallons catch fire...I bet his lmpg really dropped.
A bit extreme for me. |
I'm impressed that someone who drives around in a 15mpg Astro van is concerned about fe. Hmmmm.... how 'bout driving something that's easy on gas in the first place???
You can't fix stupid. |
Oooooh, Dick found catch cans and HHO! Scary! :eek:
I think HHO is a higher risk for explosion than most mods... not only can the mod itself explode, but the stupidity of people attempting it can make REAL Ecomodders' heads explode.
I LOLed.
Someone should have introduced the man to the unicorn corral before he started lugging 300 extra pounds of fuel around. |
Looks like a vapor fuel tank experiment reached its only logical conclusion.
I'm assuming the idea was better atomization of the fuel/air and hence better combustion efficiency?
...maybe it could work... I have a spare 55 gallon drum laying around too...:D |
As i read on fuel vaporizer things on internet, it claims that it helps to get over 400mpg. Sounds like unicorn corral topic :D
Or is there actually any savings, that was not pointed out? EDIT: Hmm, it already vaporizes while it gets out of injector, but then the system gives the needed air.. Yea, that was a hoax :D |
