EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   DiabloSport inTune- What prameters to watch (https://ecomodder.com/forum/showthread.php/diablosport-intune-what-prameters-watch-30684.html)
leanAztek 12-11-2014 11:59 PM
I have a DiabloSport inTune. This is more of a tuner than a guage but I can display about 8 parameters on the screen while driving in it's recording mode. So I am wondering what to display to help with mpg. I can't buy anymore "toys" for my car right now. :o
I could not find a instant MPG value. I did find the vacume on the intake and have been monitoring that. I found torque but the numbers are quite variable and seem hard to use as a way to adjust my driving. I will be putting oil and coolant temp on there to help me monitor temps as I add grill blocks.
So here is what I plan to display.
intake vacume
oil temp
coolant temp
RPM and MPH I can get from my dash. I also have a temp guage in the dash but based on what I read here they are not allways accurate so I want to confirm the reading for a while.
So what can I look at while using the KISS principle so I am not distracted. Thanks.
leanAztek 12-13-2014 12:28 PM
Saw a post to monitor:
rpm
throttle position
engine load
ref:http://ecomodder.com/forum/showthrea...tml#post450866
leanAztek 12-16-2014 09:19 PM
I suppose if I add brake peddle position I could analyze my trips afterword. I have to log in order to see the gauges anyway. I'm going to look for gear selection. I am trying to do Engine On Neutral Coasting.
