EcoModder.com
-   DIY / How-to (https://ecomodder.com/forum/diy-how.html)
-   -   DIY - Black Trim Painting (https://ecomodder.com/forum/showthread.php/diy-black-trim-painting-131.html)
SVOboy 11-30-2007 01:24 AM
So, guess who's painting all his trim? This is mainly a DIY for my site but I like to post my stuff up here since this is where I got my start writing DIYs, :), nothing to do with FE of course.
Anyway, it's unfinished, but big, so working in parts!
Before shot:
http://xs205.xs.to/xs205/06340/DSC00494.JPG
Before bumper:
http://xs205.xs.to/xs205/06340/DSC00495.JPG
Using two or three cans of this for the whole deal:
http://xs205.xs.to/xs205/06340/DSC00510.JPG
Piece of coroplast over a trashcan in the garage, my painting center:
http://xs205.xs.to/xs205/06340/DSC00511.JPG
An MID picture in here for no reason, that comes out to ~52 mpg for a 3 mile cold start, not bad:
http://xs205.xs.to/xs205/06340/DSC00512.JPG
Start by taking the two screws that hold the corner lights in and taking the lights out:
http://xs205.xs.to/xs205/06340/DSC00513.JPG
http://xs205.xs.to/xs205/06340/DSC00514.JPG
Make sure to store everything nicely:
http://xs205.xs.to/xs205/06340/DSC00515.JPG
Tools needed, that socket is a 10mm:
http://xs205.xs.to/xs205/06340/DSC00516.JPG
Take these two out on each side:
http://xs205.xs.to/xs205/06340/DSC00517.JPG
And this one on the bottom, this will allow you to remove the t-bar:
http://xs205.xs.to/xs205/06340/DSC00518.JPG
Get these two bolts gone:
http://xs205.xs.to/xs205/06340/DSC00519.JPG
Two of these on each side come out, might have to move the wheel a bit:
http://xs205.xs.to/xs205/06340/DSC00520.JPG
Two of these corner jobs:
http://xs205.xs.to/xs205/06340/DSC00521.JPG
Move the t-bar to expose these three things:
http://xs205.xs.to/xs205/06340/DSC00522.JPG
Start pulling the bumper off and unplug the bumper lights:
http://xs205.xs.to/xs205/06340/DSC00523.JPG
But it somewhere not scratchy:
http://xs205.xs.to/xs205/06340/DSC00524.JPG
To get at the fenders undo these two:
http://xs205.xs.to/xs205/06340/DSC00525.JPG
These three up top:
http://xs205.xs.to/xs205/06340/DSC00526.JPG
This one in the crack. Use an open-ended wrench and open the door, stand outside and reach over and do it from the crack, you'll see what I mean:
http://xs205.xs.to/xs205/06340/DSC00527.JPG
Get these screws on that bottom trim piece:
http://xs205.xs.to/xs205/06340/DSC00528.JPG
The bolt on the bottom as well:
http://xs205.xs.to/xs205/06340/DSC00529.JPG
When it's off hit up these two last bolts for the fender:
http://xs205.xs.to/xs205/06340/DSC00530.JPG
Get bored and work on this piece of trim instead:
http://xs205.xs.to/xs205/06340/DSC00531.JPG
Blast it with the hose, the suds, the hose:
http://xs205.xs.to/xs205/06340/DSC00532.JPG
Then clean it with alcohol and let it dry:
http://xs205.xs.to/xs205/06340/DSC00533.JPG
Here it is drying:
http://xs205.xs.to/xs205/06340/DSC00534.JPG
Work on the rocker panel while it dies, these plastic screws suck, you need to be very careful, especially with the ones that are more exposed:
http://xs205.xs.to/xs205/06340/DSC00536.JPG
Yay, I stripped one:
http://xs205.xs.to/xs205/06340/DSC00537.JPG
Grabbed the edge with some pliers and turned it out like that. I always leave the last few threads in the thing and use them to pull the whole thing out as one:
http://xs205.xs.to/xs205/06340/DSC00538.JPG
Some more up top:
http://xs205.xs.to/xs205/06340/DSC00539.JPG
Even more up top:
http://xs205.xs.to/xs205/06340/DSC00540.JPG
Now, get bored of that and work in the other piece that on the door. Take off this 10mm plastic nut:
http://xs205.xs.to/xs205/06340/DSC00541.JPG
This is how it clips in along the bottom, the first task is to unclip:
http://xs205.xs.to/xs205/06340/DSC00542.JPG
Half unclipped first:
http://xs205.xs.to/xs205/06340/DSC00543.JPG
Go ahead and fully unclip and then push up to get it off the metal rail:
http://xs205.xs.to/xs205/06340/DSC00544.JPG
Get bored again and decide to finish the fender, undo all the plasticy junk in the wheel well:
http://xs205.xs.to/xs205/06340/DSC00545.JPG
Fender out:
http://xs205.xs.to/xs205/06340/DSC00546.JPG
Flip it over to expose the two clips for the trim piece, pop them with some pliers:
http://xs205.xs.to/xs205/06340/DSC00547.JPG
Yay, it's so pretty:
http://xs205.xs.to/xs205/06340/DSC00548.JPG
Hit that first piece with some paint, drying at this point:
http://xs205.xs.to/xs205/06340/DSC00549.JPG
Not that this is a vertical line spray, you need to hold the can vertical to keep it going and work in a smooth, sweeping motion:
http://xs205.xs.to/xs205/06340/DSC00550.JPG
With time, there will be more.
metroschultz 12-29-2007 11:02 AM
those plastic retainers w/ small plastic screw in the middle can be removed veerryy easily with a small pointed pick. Put the point of the pick into the screw portion just under the head where it meets the wide part of the body and pry gently. a screwdriver will tear them up in a heartbeat, once the head is out 4 or 5 threads just pull like you were. whole retainer comes out and is re-usable. BUT if you accidentally destroy one they are available on NAPA.com i believe they were 10 in pack for $5. S.
SVOboy 12-29-2007 12:01 PM
That's for the tip! I never even though of buying more, :)
I'll have to get a pick at some point, too.
metroschultz 12-29-2007 12:34 PM
I didn't think about buying them until i need quite a few for my interior. My local Chevy dealer wanted $1.5 (approx, my memory is fading) for a two pack. Google here i come. lo and behold it led me straight to NAPA. S.
DifferentPointofView 12-29-2007 01:25 PM
Which is why I don't like going to a dealer for parts because everything costs 3 times as much as you can buy it across the street!!!
trebuchet03 11-20-2008 11:10 AM
Is that a texture paint?
Because I've been considering how to finish my JettKamm - and I'm thinking of a black texture - like die injected plastic trim bits. Will hide imperfections, give it a "stock" look and is generally easy to apply.
Or I might buy my father (who does finishing professionally) a throw away gun and see about painting it with glossy black epoxy paint :)
And omg picture overload!
femina 12-13-2008 04:39 AM
Hi, I am a 24 years old. I am currently taking a beginners painting class, and I am also an art major. I seem to always fall under the same style of painting, mostly impasto impressionism. I would really like to break away from this style. I thought about doing my next assignment based on a portrait with best technique, but I am afraid on how to begin with this and what sort of brushes I should use. Any helpful recommend will be greatly appreciated.
i_am_socket 12-13-2008 12:09 PM
Hi, I love tomato bisque soup and I'm wondering if you have any suggestions on how to make my spackle taste more like tomato bisque soup. Right now I have a lovely bunch of coconuts sitting in a row; large ones, small ones, some as big as your head. But, yes, we have no bananas today.
http://spidermouse.us/images/smilies/freak.gif
Seriously?
Nice thorough work so far SVO :thumbup:
gascort 12-13-2008 10:59 PM
Seriously?
Usually, ROFL is an exaggeration... :D:D:D:D:D
I apparently need to move to warmer climes; it looks warm there with green grass and no socks/shoes on 11/30...
SVOboy 12-13-2008 11:30 PM
I am also confused.
Christ 12-14-2008 01:10 AM
Ew... toe shots.
Seriously, you didn't HAVE to do half the work you did there to get those pieces off.
The trim piece on the fender comes off easily without removing the fender, and you can remove the entire bumper, cover and all, with (usually) two bolts.
If you remove the bumper lenses from the car, set them aside, and look inside, you can use a 3/8" Drive 6" extension and a 10mm ratchet to disconnect the bumper from the car completely, then remove those small Philips head screws on either side of the cover, (in the fender wells) and it will literally fall off the car, where you can have better access to all those screws that hold the cover to the bumper.
For the fender trim bar, remove a few of the fasteners from the inner fender on the back side, pull it away, and use any small pair of pliers to engage those two clips, while pulling at it from the visible side or prying with something small and not-scratchy. (I use plastic silverware a lot on cars.)
Also, your corner lenses should NOT have a screw visible in them at all. That was one of the aesthetic changes to the 90-91 Civic/CR-X models, they shaved the fasteners from the corner lenses. Someone must have put it there of their own accord.
There is absolutely no difference in the fenders of the 90-91 vs. the 88-89 cars, other than the plastic screw receptacles in the fenders of the 88-89 models were filled with strut receptacles for the 90-91 model years, while the lenses themselves were given tabs that coincided with the old-style's screw location that engaged those strut receptacles to prevent lateral movement of the lens/housing assembly.
Also, if you don't want to paint all that trim, and you still want it to be shiny black, Mother's makes a great polish for it, and peanut butter or peanut oil will actually bring back the OEM appearance of the rubber bits. (Not the plastic though.)
Other than all that, good work on the walk-through, and hope to see more detailed posts in the future. :thumbup:
some_other_dave 12-15-2008 02:46 PM
Originally Posted by SVOboy (Post 78333)
I am also confused.
It's simple--"femina" is a spammer. S/He probably has links to some sales-type website in his/her profile, in an attempt to drive up the Google rating of said site. It may even be a site that has something to do with paint...
-soD
DifferentPointofView 12-15-2008 10:27 PM
oh, nice CRX SVO. How long have you had it? I've never seen one in such good condition before (besides the restored ones).
bluesfan 12-15-2008 10:43 PM
Originally Posted by Christ (Post 78348)
...your corner lenses should NOT have a screw visible in them at all. That was one of the aesthetic changes to the 90-91 Civic/CR-X models, they shaved the fasteners from the corner lenses. Someone must have put it there of their own accord.
Honda humor?
P.S. Many happy returns on your upcoming birthday :D
Christ 12-15-2008 10:46 PM
Originally Posted by bluesfan (Post 78693)
Honda humor?
GAH!.. someone noticed the b-day. I'm gonna melt now.
The "accord comment" was actually completely unintentional... I wish I had noticed it when I posted it... I could have made it a prelude for another quip. :thumbup:
