DIY d-series Civic water pump idler plate
1 Attachment(s)
I took my daily driver, "black & green," off the road today for a week of service and mods, and I have a question for the forum. Anyone ever fabricated their own idler plate for a water pump?
I am considering cutting the impellers off my stock water pump, which works fine. Here is a picture of an OEM style d-series water pump, showing its impellers: http://ecomodder.com/forum/attachmen...1&d=1465426455 I have checked honda-tech.com and d-series.org ... and I know about Meziere electric pumps (they are not available for d-series honda engines). Here is a water pump I am considering... I have not checked how its specs compare with the stock water volume and flow rate yet: 12V DC 4A EV Hot Water-Coolant Pump 200F-100C EV Hot Water-Coolant Pump 9 Gallon-min 35 Liters-min [EDIT:] Or this Craig Davies pump: http://daviescraig.com.au/product/ew...ric-water-pump Thoughts? |
I'd be concerned with the first pump. MAX working temp is 100C. The housing is plastic. Not that it won't hold up, but I'd rather not take the chance. You have a perfectly good water pump already on the car. Just find a way to spin it with an electric motor. Its probably cheaper too.
My setup: http://ecomodder.com/forum/showthrea...eap-29896.html |
