Old 06-08-2016, 08:00 PM   #1 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
DIY d-series Civic water pump idler plate
I took my daily driver, "black & green," off the road today for a week of service and mods, and I have a question for the forum. Anyone ever fabricated their own idler plate for a water pump?
I am considering cutting the impellers off my stock water pump, which works fine. Here is a picture of an OEM style d-series water pump, showing its impellers:
I have checked honda-tech.com and d-series.org ... and I know about Meziere electric pumps (they are not available for d-series honda engines).
Here is a water pump I am considering... I have not checked how its specs compare with the stock water volume and flow rate yet:
12V DC 4A EV Hot Water-Coolant Pump 200F-100C EV Hot Water-Coolant Pump 9 Gallon-min 35 Liters-min
[EDIT:] Or this Craig Davies pump:
http://daviescraig.com.au/product/ew...ric-water-pump
Thoughts?
Old 06-09-2016, 10:58 AM   #2 (permalink)
I'd be concerned with the first pump. MAX working temp is 100C. The housing is plastic. Not that it won't hold up, but I'd rather not take the chance. You have a perfectly good water pump already on the car. Just find a way to spin it with an electric motor. Its probably cheaper too.
My setup:
http://ecomodder.com/forum/showthrea...eap-29896.html
The Following User Says Thank You to Daox For This Useful Post:
California98Civic (06-09-2016)
Old 06-09-2016, 12:24 PM   #3 (permalink)
Cyborg ECU
... You have a perfectly good water pump already on the car. Just find a way to spin it with an electric motor. Its probably cheaper too. ...
That is true, of course. The only issue is that the d-series Honda waterpump is driven by the timing belt, so it is under the timing cover. And taking the pump off the belt would mean I'd need a non-OEM shorter replacement belt for the engine critical role of timing. Seems like a mistake could ruin my engine. And I think the appropriate manufacturer of a shorter belt would be hard to indentify. The belt and pulleys are grooved.
Old 06-09-2016, 12:33 PM   #4 (permalink)
Aha, yeah that stinks.
