Go Back   EcoModder Forum > EcoModding > EcoModder Blog Discussion
Old 11-02-2011, 04:50 PM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
ScanGauge-E Review and Compairison
A few months back, Darin and Ben (EM’s owners) asked me to review the new ScanGauge-E. I gladly accepted and tried it out for a few weeks. You can see the full review here. For the blog we’ll keep it short and to the point. First up we’ll look at some of the limitations of [...]
More...
Old 11-03-2011, 08:45 AM   #2 (permalink)
Fizz - '06 Skoda Fabia Combi
90 day: 56.62 mpg (US)
I have a mpg display on my Skoda Fabia which I use a lot; however the update rate is slow (maybe every 2 seconds). Do you think the Scangauge would give any advantage over my factory mpg readout?
thanks
Old 11-03-2011, 09:18 AM   #3 (permalink)
The scangauge is far superior to a factory mpg readout, but not because it refreshes faster, its all the other functionality that helps out a lot more than just the mpg readout.
Old 11-03-2011, 10:58 AM   #4 (permalink)
I've got one on its way - cant wait. Any tips on what displays to use for a small turbo-diesel most appreciated!
Old 11-03-2011, 03:25 PM   #5 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
The main issue I have with the ScanGauge on my diesel, is they calculate fuel use.
They don't get calibrated to your car, but to your driving style.
Calibrate it, then change the way you drive, and it'll be off.
Old 11-07-2011, 11:31 AM   #6 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
I've been looking at getting either a Scangauge-E or ScangaugeII for a while now. One question I have is whether either (or both of them) will give me info other than MPG, like %load, timing, fan speed, etc.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 11-07-2011, 11:37 AM   #7 (permalink)
ScanGaugeII
ScanGauge-E
On the bottom click on the "Digital Gauges" tab and you can see everything that the SG will display (assuming your engine has a sensor for it).
