DIY: Make a PVC Catch Can for your PCV System
This won't be one of my best DIYs simply because I didn't take pictures while I made it. You should be able to get the gist of it enough so that you too can make a PVC PCV System Catch Can! :D
Things You'll Need:
What To Do: Cut your section of PVC pipe down to about 9" http://www.thelic.org/users/tomo/PCV7.jpg Clean and glue on the NON-Threaded cap to one end and the threaded end on the other end of the cut pipe: http://www.thelic.org/users/tomo/PCV6.jpg Drill two holes in the threaded cap just large enough to screw in the 90° adapters, then screw in the barbed fittings: http://www.thelic.org/users/tomo/PCV9.jpg http://www.thelic.org/users/tomo/PCV10.jpg Cut a chunk of the rest of the PVC pipe off that is roughly 1" wide and 3" long. JB weld it in between the fittings inside the threaded cap: http://www.thelic.org/users/tomo/PCV8.jpg (This serves to divert the incoming air so the stainless steel scrub pad has a chance to help remove the oil droplets as well as helping to hold the brass fittings in place) Let the JB Weld setup Paint the Catch Can (optional): http://www.thelic.org/users/tomo/PCV12.jpg Install hoses and place the entire scrub pad down into the tube assembly you made earlier: http://www.thelic.org/users/tomo/PCV11.jpg Install in a high point (higher than the engine block) in the engine compartment (I zip tied mine up next to the brake master cylinder for now): http://www.thelic.org/users/tomo/PCV13.jpg Not the Best DIY but it was cheap as I had the JB weld and PVC cleaner and glue already. The PVC components were less than $6. Feel free to post comments and questions here. :thumbup: :D |
