Do people steal metros?
Wondering if I should get a security device for my cute new little car.
In Alberta? Doubtful it will be messed with. If it makes you feel better a cheap security system could be set up to prevent the vehicle from being started. Include a back up battery to ensure it will work if the car's battery is disconnected. If you want to go really cheap, put a switch in line with the starter 12v+ wire.
The best security device would be lots of coroplast. Use different colors if you really want to be safe. ;)
There are a lot of "financial combustion" thefts in Alberta when oil prices drop and all the oil sands workers can't make their $1500 a month new diesel pickup payments anymore. But I wouldn't think a Metro would be high on the list, though they are easy to take, and if I was a young hoodlum walking around in the cold in the winter I would rather take a Metro than walk. So anything you can do to make it look like more work than it is worth to take would help. Immobilizer is good, but by the time they figure out they can't take it they have already punched the lock or bent the window frame out on the door. I'd get a cheap club for the wheel, people can get around them, but more likely they will just move on to the next car with nothing in it. Just my 2 cents.
Three stick of dynamite under the front seat. No which way does that switch go? LOL
As much as I'd like a kill switch on the fuel injector and a start button, from the threads I saw on here, I don't have the tools or knowledge to do it myself. :S Can you get people to do this for you at a mechanic shop?
regards Mech |
For the price of tools and a few hours of reading, you will be able to do it yourself. Any car electronics place can do it for you if you really don't have the desire to learn how to do it.
Just remove the fuse for the fuel pump if it's easy to reach when the car is parked in an ''unsafe zone''
You could also use that technique on other fuses too! There's another aproach, a 30-50w siren tucked under passenger seat. Siren will start with a time delay of 5-10sec once the car is started if you don't flip a switch. You'll be sure thief will leave the car there. |
