EcoModder.com
-   DIY / How-to (https://ecomodder.com/forum/diy-how.html)
-   -   Do Pulstar Pulse plugs work? (https://ecomodder.com/forum/showthread.php/do-pulstar-pulse-plugs-work-4020.html)
Z man 07-24-2008 01:56 AM
Sorry if this has been covered somewhere, but would these plugs be a good investment?
If anyone has Pulstars tell me if they work!
If not, what are the best spark plugs to have?
Daox 07-24-2008 07:55 AM
I just put a set in my Paseo that I got for testing. I'll let you know what happens. So far they don't fit correctly though. They are too tall. The others that have also gotten them for testing have seen no real gains. Its not looking like this tank is anything special either, however its only halfway through.
Ryland 07-24-2008 08:37 AM
I have not seen any gains either, on my 5th tank of gas with these plugs, no fitment issue on my civic.
I've tried other plugs as well, like the Bosch +4 and I did have trouble with my civic not running as smooth with those plugs.
I plan to switch back to NGK copper core v-power plugs that are recommended by Honda next time I change plugs, I've always had good luck with them.
Will 07-24-2008 09:47 AM
I am glad to see us getting some data on this issue. There is so much crap out there about plugs.
I have had great luck with the NGKs in my Mertro, too.
dann_04 07-24-2008 09:53 AM
In sohc engines(like my old metro and escort and dads jetta) i saw the best improvement with autolite platinum plugs. They are cheap from walmart and worked well. Bosch have a wierd thing where the way they route the spark tends to slow it down very minutely, but enough to basically retard the timing so anything i have tried those things on have lost alot of power and mileage. On the dohc(my civic si and my g/fs old tracker) i saw the best gains with ngk iridium plugs. My scooters and mothe rin laws bike run best on iridiums as well(i think its the fact that the tiny electrode doesn't get as dirty because it's so small). But those are my findings so far. Haven't tried pulstar though.
PaleMelanesian 07-24-2008 10:25 AM
Someone recorded a lot of data about them here:
Brick's Pulse Plug test thread - CleanMPG Forums
99clipsgst 07-24-2008 12:14 PM
They had an episode of Horsepower TV on Spike that tested these plugs vs. the standard plug. To test they ran the engine on a dyno the let everything cool down and run again with the pulstar plugs. The results fuel wise was minimal but they did gain 2 hp and 1.5 lb/ft. With that being on a Chevy 350 I doubt the plugs will make any diffrence on a 4 banger.
PaleMelanesian 07-24-2008 12:25 PM
2hp, 1.5 torque? That's less than 1% on a V8. That's easily within the noise of testing variations. Add in the fact that these are EXPENSIVE, and it's clearly not worth it.
Z man 07-24-2008 12:28 PM
Well that's what I pretty much assumed. I wish they did work, it would be an easy change.
That's funny that the pulse plugs didn't fit.:eek:
There's a lot of stuff about the NGK Iridium plugs improving mileage.
Tony Raine 07-24-2008 01:20 PM
i've tried e3 plugs, among others, and never noticed a measurable difference. i just use whatever plug the factory recommends.
